Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 05-25-2009, 05:09 AM   #1
Crinos is an unknown quantity at this point
Speed on ODBII reading -> output
I see many virtual gauges for both speed and RPM, but the videos I have seen usually show some latency and very often peak spikes.
Is there a way to get this 100% accurate? With 0% fail...
If not, I realy do not see the big picture of having a ODBII scanner, reader in my car, since I can get pretty much everything I want out from the IBUS. (BMW)
Crinos is offline   Reply With Quote
Old 05-25-2009, 05:52 AM   #2
p2psmurf is an unknown quantity at this point
Readout speed depends on
a) the protocol used
b) how many ecu's respond to that protocol
Obviously a Iso 9141-2 protocol running at 10.400 baud is a lot slower than a Can protocol running at 500K baud.
Also the timeouts between messages are greater when using Iso protocols.
For instance it is very normal for a car to wait 25 - 30 mili seconds after receiving the checksum of a command, before sending the answer. The second ecu will even wait a little bit longer, say about 30 - 35 mili seconds.
Then the scantool has to wait for 55 miliseconds after receiving the checksum of the last message from the last ecu, before it can send another command.
These delays will slow down the transfer rate significantly.
Bmw's normally have 1 ecu for the engine, except some 12 cylinders, who have 3 ecu's for the engine, which all respond. When you have an automatic gearbox, that ecu will also respond.
p2psmurf is offline   Reply With Quote
Old 05-25-2009, 07:12 AM   #3
Thank you for a detailed answer!
Then it's clear for me, that I do not need any ODBII devices/programs... Atleast not for the moment
Old 05-26-2009, 05:06 AM   #4
VENDOR - ScanTool
Vitaliy is on a distinguished road
What would you say be an acceptable refresh rate (in samples per second)?
With some tweaking, it is possible to get reasonably fast (~10 samples/sec), even on ISO.
Vitaliy
— Did you know that MP3Car sells OBD-2 interfaces? Get your ElmScan 5 Compact for only $59.95!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
Vitaliy is offline   Reply With Quote
Old 05-26-2009, 06:56 AM   #5
Vitaliy
10 samples / sec sound fast enough, but I realy do not have a clue
For me, it should be equal to stock, so that I could mount a LCD infront of stock dashgauges and use my custom screen...
This way I could go with a big RPM and tiny speed while driving active, and vice versa while driving normal.
And active road assistance while driving to a GPS location.
Old 05-26-2009, 07:05 AM   #6
10 samples per second for RPM is too slow, at least in my opinion.
It'll do for 3rd and higher gears, but not in 1st and 2nd, there you will hit the limiter.
Besides, 10 samples is when you only read 1 (ONE) item at a time.
When you need both Rpm and Vehicle speed you will get 5 to 6 samples a second.
Old 05-26-2009, 11:13 AM   #7
Mod - OBDII GPS Logger forum
chunkyks is on a distinguished road
FWIW, I empirically checked the samplerate with my new OBDPros USB device, and was getting a little over 20 samples per second. My OBDKey Bluetooth would do between five and seven. I find that 20 samples per second is actually a pretty large number.
Gary (-;
chunkyks is online now   Reply With Quote
Old 05-26-2009, 01:06 PM   #8
wonder of what rate the stock system would report... if even possible to compare them
Old 05-26-2009, 02:05 PM   #9
Refresh rate on stock systems depends on the protocol used and the baudrate.
Exanple 1: Bmw diesel at 250 baud. Internal there are 2 ecu's. So, first ecu 1 asks ecu 2 some things. Then ecu 1 responds with a 40 mili delay between each character.
Then the scanner has to echo each character. At 250 baud 1 character takes 40 mili.
Reading codes and some data (8 items) takes up to 10 seconds.
Example 2: Opel Iso-81 and Iso-82 protocols at 9600 baud.
Scanner requests data and ecu repeatedly sends everything at full speed.
Packets are 40 - 80 bytes, which gives you 20 - 10 packets every second.
But hey, stock system means only 1 ecu responds, not maximum 8 as specified in OBD2 and EOBD (Sae J1979).
Old 05-27-2009, 04:13 AM   #10
VENDOR - ScanTool
Gary (-;
On what protocol?
Old 05-27-2009, 10:19 AM   #11
On what protocol?
Erm, not entirely sure. Whatever my car [2009 Cooper S] does by default. Next time I'm sitting in my car with my laptop I'll figure it out.
Gary (-;
Old 05-27-2009, 10:24 AM   #12
2009 models use Can. Can is obligated from 2008 on.
Old 05-28-2009, 01:14 AM   #13
VENDOR - ScanTool
Gary (-;
It's CAN. 20 samples per second is expected in your situation.
Best regards,
Vitaliy
Old 05-28-2009, 12:11 PM   #14
Magistertc is an unknown quantity at this point
I routinely average over 50 PIDs/sec. This is with XP on a three-year old laptop, with a 2007 Civic, ELM327 v1.3 and CAN29/500, at 500Kbaud. Speed will drop to 30-40 when the hard drive needs defragmenting. Max is about 65 when I limit the number of PIDs being monitored.
On my 2001 Accord (ISO) I seldom see anything over 15 PIDs/sec.
Some demo programs I have tried will not reach this speed. YMMV.
[IMG][/IMG]
Magistertc is offline   Reply With Quote
Old 05-31-2009, 08:33 PM   #15
Screenshot from a more recent acquisition - OBDPro USB.
Same vehicle, 2007 Civic LX, same laptop, just about the same, 55 PIDs/sec
[/url][IMG][url='http://www.mp3car.com/vbulletin/vbimghost.php?do=displayimg&imgid=9681']
m10000 on-board -> audigy 2 nx -> m10000 on-board fatman Car Audio 7 02-21-2008 12:49 PM
Reading ODBII from SCT XCaliber 2 Hessian Engine Management, OBD-II, Engine Diagnostics, etc. 2 06-28-2007 08:47 PM
Whats up with Geiss? Was working before but not now? PDiddy Centrafuse 7 07-01-2005 04:29 PM
Speed Reading Skuzzle Map Monkey 9 12-28-2004 04:04 PM
Is all coax/optical spdif output created equal? Choser General Hardware Discussion 26 12-19-2004 03:48 PM
