Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 05-28-2009, 08:10 PM   #1
iNcArCeRaTiOn is an unknown quantity at this point
I'm an OBD-II noob. Please help, lol.
I just recently ordered and received a USB OBD-II Scantool from OBDPros
I'm pretty sure it's the ELM327 chip or whatever
I'm trying to find a program that i can get free or whatever that works well this tool. I'm also looking for one that gives MPG functionality or how i can put in my car's information to generate MPG (tank size and engine size etc)
any suggestions? i've tried the following programs
- EasyOBDII 2.2.0
- OBD DIAG (standard i think)
- ProScan 5.0 (i think a trial or something i'm not sure)
Thanks =]
2006 Mazda 3 S Series
2.3L 4cyl Engine
Current Build
- Commell LV-677 Motherboard
- Intel Core 2 Duo T5500 CPU
- Dual 512MB PC5300\667MHz RAM
- Seagate 80GB SATA HDD
- M2-ATX 160W PSU
- Dynamix 8" LCD Touchscreen
- VoomPC I Mini-ITX Case (Black)
iNcArCeRaTiOn is offline   Reply With Quote
Old 05-28-2009, 08:58 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Ride Runner with the OBDII plug-in will do what you want.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 05-28-2009, 09:01 PM   #3
i've got RideRunner installed with DFX4.0, everything's working great.
but i'm not quite sure how to install the OBDMPG plugin. i read the directions, did everything word for word. but where do i go to access it within RideRunner (i have DFX4.0 active atm and it's the only skin installed)
thanks
2.3L 4cyl Engine
Current Build
- M2-ATX 160W PSU
Old 05-28-2009, 11:35 PM   #4
Bugbyte's Avatar
You'll have to install a skin that works with the OBD plug-in.
Want to:
-Where is the iBug?
Old 05-29-2009, 12:47 AM   #5
ok i figured that out.
i had removed all skins except the skin i was using (DFX4.0).
i installed the skin that comes with the installation and i'm getting OBDMPG in the plugin menu but i keep getting this error:
"Run-time error '11': Division by zero"
i'm using the Carwings skin pretty stripped down just to get this plugin to work.
here's my OBDMPG.ini file...
[COMMUNICATION]
COM=4
[VEHICLE]
MAF=TRUE
LITERS=2.3
VE=80
TANK=14.5
[AVERAGE]
NUM=1
AVG=0
DST=0
FUEL=0
[OPTIONS]
ExtraOBD=FALSE
METRIC=FALSE
UNITS=FALSE
i've done a search within the OBDMPG thread and haven't found any help. i've seen others with the same error but no resolution...
oh and i've tried the 9600 dll and the regular one. same problem...
thanks for any help\suggestions
2.3L 4cyl Engine
Current Build
- M2-ATX 160W PSU
OBD II Updates kb416 Engine Management, OBD-II, Engine Diagnostics, etc. 8 03-04-2009 03:14 AM
Pocket-Pc OBD II ? paul1 Engine Management, OBD-II, Engine Diagnostics, etc. 14 11-19-2008 02:26 PM
Vauxhall Astra 1.4LS year 2000 OBD II port nick_carntowan Engine Management, OBD-II, Engine Diagnostics, etc. 1 09-24-2007 02:58 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
OBD II from Walmart...USB works? sgtpepperaut Engine Management, OBD-II, Engine Diagnostics, etc. 5 05-01-2007 01:10 PM
