Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 06-18-2009, 02:24 PM   #16
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
Upon talking to an EE sitting next to me, he said that most microcontroller analog inputs are so high impedance to make it a non issue and you won't get any voltage drop. Perhaps 2k1toaster could pop by and confirm that the PIC chip the fb uses is high impedance on the analog inputs?
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 06-18-2009, 02:24 PM   #17
Mod - OBDII GPS Logger forum
chunkyks is on a distinguished road
Bugbyte: no, hadn't found that thread yet. I first discovered there was such a thing as fusion brain about half an hour ago. Perhaps tripzero could throw in his 0.2 if he lurks on this forum still?
malcolm: Diffs are always welcome - especially from you, who unwittingly wrote a large part of the code in obdsim already [although that amount as a percentage is decreasing rapidly!] :-)
Also, malcolm, I had to make some changes to make the code run on OSX and on OpenSolaris - the OSX changes are in my repo already [eg, using posix_openpt(3) instead of hardcoding the linux on-filesystem equivalent], the OpenSolaris ones need a bit more testing before I'm going to commit them. You might find some of these changes useful to feed back into your own sim. [I ripped out windows support, though, since for now I have neither the urge nor the capability to support it - if anyone contributes patches for windows for obdsim, I'd definitely welcome them]
The manpages for pts(4) and pty(7) also make good reading. I think you need to use grantpt(3) and unlockpt(3) in your sim to be properly safe.
Gary (-;
chunkyks is offline   Reply With Quote
Old 06-18-2009, 02:29 PM   #18
Oh, and by the way; the current plugin API is limited in that you can only have one data generator plugged in at a time, changed at compile-time. I have the pattern worked out in my head to make all generators available in the same binary, but it will be a couple of [small] API changes.
If anyone actually writes code in the time between now and then [probably a couple days], then some extra fluff will be necessary to make it fit. I'm keeping the current set of functions prototypes in datasource.c, though, so the change will be very easy.
Gary (-;
Old 06-18-2009, 02:59 PM   #19
cgalpin is an unknown quantity at this point
Thanks for the info malcom2073. I'd love to hear what 2k1Toaster has to say about it too.
cgalpin is offline   Reply With Quote
Old 06-21-2009, 01:42 PM   #20
The dbus - fusion brain thing is done, by the way, as is the ability to have multiple plugins all compiled in at once.
I mentioned it on the fusion brain forum here: http://www.mp3car.com/vbulletin/fusi...ion-brain.html
Have fun,
Gary (-;
Old 06-22-2009, 09:36 AM   #21
Thanks Gary. Will give it a spin once I get my sensor issues resolved.
Old 06-23-2009, 06:40 PM   #22
Also, after some discussion on IRC the other day, I implemented a dlopen plugin so that you can dynamically load libraries instead of needing to compile them in. This should be more appealing to people wishing to keep their source closed.
Example usage might be:
Code:
obdsim -g dlopen -s /usr/local/lib/libobdsimdl_vagcom.so
Assuming anyone writes a vag-com interface and was wanting to keep it closed, of course.
Gary (-;
Old 06-23-2009, 08:03 PM   #23
Have fun,
Gary (-;
I gave my feedback there, but excellent job Gary - works a treat!
Old 06-23-2009, 09:33 PM   #24
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
Video or it never happened.
LinuxICE2 beta2 is released!!! get it now!
OpenICE - The Free infotainment platform.
Follow OpenICE development
kev000 is offline   Reply With Quote
Old 06-24-2009, 07:55 AM   #25
LOL. Not much to see other than me running my fingers over the analog input pins to create some data, and 3 shells spitting out data This description would be more informative:
sensor (or me) -[volts]-> FB -[USB]-> fbd - [dbus] -> obdsim - [OBDII/ELM]-> obdlogger
I guess I can try obdgui at some point and show me warming/cooling a temp sensor or something.
Old 06-24-2009, 05:15 PM   #26
It occurred to me that this would make an excellent poor man's partially-hardware obd simulator. Not sure exactly how much use it would be, but a couple pots, an FB, and you'd be gold
Gary (-;
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
