Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 06-27-2009, 09:48 AM   #1
searcherrr is an unknown quantity at this point
Question OBDII software that shows Vehicle Calibration ID
I am in a very desperate situation and I urgently need to verify the vehicle calibration id (or code) that is in use on the PCM I have installed in my vehicle. A new PCM was just installed, and I don't think its flashed right.
Is there any free program that anyone is "POSITIVE" shows me the VEHICLE CALIBRATION CODE in use in the PCM?
I'm getting like 6-8mpg and have been troubleshooting a MPG problem for over 2 years.
searcherrr is offline   Reply With Quote
Advertisement Sponsored links
Old 06-27-2009, 11:11 AM   #2
VENDOR - ScanTool
Vitaliy is on a distinguished road
I don't know of any free software, but ScanMaster definitely supports it.
Do you have any kind of PC-based scan tool? You can request CalID manually (using a terminal), and we can help you decode it.
— Did you know that MP3Car sells OBD-2 interfaces? Get your ElmScan 5 Compact for only $64.95!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
Vitaliy is offline   Reply With Quote
Old 06-27-2009, 03:05 PM   #3
PPE
PPE's Avatar
PPE is on a distinguished road
Our ScanXL software will show you the Calibration IDs for all OBD-II modules in the vehicle that report that information. It will also show you the CVN numbers from each of the modules.
If all you want is just the calibration numbers, our ScanXL software will show you that without you having to purchase a license for it. Just connect to the vehicle and go to the OBD-II Settings tab to view it.
You can download the latest version from here.
Brian @ Palmer Performance Engineering, Inc.
http://www.palmerperformance.com
PPE is offline   Reply With Quote
Old 06-27-2009, 08:13 PM   #4
Thumbs up
You guys rock! I really can't tell you enough how much this helps me out. To be able to eliminate this as a possible culprit with my OWN eyes, instead of trusting the shop, is invaluable. I am in the middle of a 2 year long ordeal trying to get this vehicle right.
Thank you PPE for letting me know the trial version will give me that information. I'm downloading it now.
PPE - Does your company sell anything that produces diagnostics/analysis..... like that would do a summary review of a drive and then state the results and/or if there are any problems? Is something like that REALLY MEGA expensive?
Vitaliy - I'm an IT person, so I am interested in querying it manually too. Do I use telnet or something like that? What are the commands necessary? Assume I'm an advanced user, but explain what software method I would use.
Old 06-27-2009, 08:17 PM   #5
OH, and I am using a scan tool "INTERFACE" that I bought for about $30 from Tokyo. It is an ELM device, but I do not know the version. I can tell you though it supports EOBD, OBD, CAN and says RoHs Compliant (OBDII) and it connects via USB. It is using a FTDI manufactured driver and says its at location "FT232R USB UART" in the device manager of Windows XP.
Old 06-27-2009, 09:23 PM   #6
The 1995 3.8L Ford Windstar is OBDII compliant. When i load ScanXL the only option for connection is Generic OBDII, but this doesn't give me anything at all in the OBD settings tab for vehicle information. All it says is $10 Engine computer. I also tried setting it up for the 1996 Windstar and tried the various connection options "Ford Powertrain" etc... and I still am not getting ANY type of vehicle specific information such as calibration ID. HOW COME?
Old 06-28-2009, 02:03 AM   #7
VENDOR - ScanTool
Set up Hyperterminal for 38400 (or 9600 baud), then try:
ATSP0
0100
011C
0900
0902
0904
If you bought an ElmScan 5, you could use STNFinder utility to find which port it's on, but for your interface you have to look in Device Manager/ports and see if you can guess which one it is.
Best regards,
Vitaliy
Old 06-28-2009, 07:44 AM   #8
Vitaliy - I'm assuming that you want me to hit enter after every one of those numbers? correct?
Also, each of those alphanumerics is a command right?
These are the universal OBDII query commands that get me engine calibration ID?
Before I try this does it matter that the PCM is a 3rd party PCM?
Old 06-29-2009, 02:41 AM   #9
Haven't used hyperterminal in ages, but i'm pretty sure i connected it right. it says its connected and i chose com4 cause thats what it is, but when i try to type anything in the white space window of hyperterminal no text appears. What am I missing here?
Old 06-29-2009, 02:56 AM   #10
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
Hyperterminal has options to show what you type or not. A lot of chips have an echo feature which sends back whatever it received, you would want to turn that on. Don't know what the command is, but you'll want to find it and type it in first (without seeing what you wrote of course), and after that you should be able to see it
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 06-29-2009, 03:01 AM   #11
ok, Vitaliy - here's what I got from those commands (was able to do it using another OBD program):
ATZ ELM327 v1.3
ATE0 OK
>ATSP0 OK
>0100 SEARCHING...
>0100 41 0 BF 9F B9 80
>011C NO DATA
>0900 NO DATA
>0902 NO DATA
>0904 NO DATA
What does all that mean? HOw come NO DATA for all those? What does the one that looks like a mac address mean?
Old 06-29-2009, 04:31 AM   #12
Tomin is an unknown quantity at this point
I have on a table EEC from European Ford Mondeo 2.5V6 (year 96) and it signals to me that it is only OBD I (one, not II). It is still protocol Ford PWM/SCP, but can not answer on many PIDs. Only very few pids is accessible. Not Lambda tests, ....
Is there any cheap soft solution for it ?
Tomin is offline   Reply With Quote
Old 06-30-2009, 12:32 PM   #13
VENDOR - ScanTool
ATZ ELM327 v1.3
ATE0 OK
>ATSP0 OK
>0100 SEARCHING...
>011C NO DATA
>0900 NO DATA
>0902 NO DATA
>0904 NO DATA
PID 00 reported the following PIDs as "supported": 01, 03, 04, 05, 06, 07, 08, 09, 0C, 0D, 0E, 0F, 10, 11, 13, 14, 15, 18, 19. That's a lot of PIDs, but 1C ("OBD system requirements") is not supported, meaning that the vehicle is not OBD-2 compliant.
Further, when you sent "0900" you asked the vehicle which infotypes (CalID, CVN, VIN, IPT, ECUNAME) are supported. It responded with "NO DATA", meaning that none are supported. So then, of course, you got "NO DATA" when you requested VIN and CALID (0902 and 0904).
So unfortunately, your Windstar is not OBD-2 compliant. Does it have a sticker under the hood, that says it is?
Vitaliy
Old 07-01-2009, 01:35 AM   #14
It is OBDII compliant. I have had Autozone, myself, and others use OBDII code readers on it before.
The X variable here is that I have a 3rd party PCM installed and I'm wondering if because its not the OEM PCM if its lacking some typical data it should have. IE: CalID is necessary for proper engine functioning. For it not to be in there scares me.
I will look at the sticker for you, but I already know the 95 3.8L Windstar is OBD2.
I also recently have gotten "Vehicle Data Bus Corrupted" error msg while using the EasyOBDII program after going WOT and I got disconnected. I wonder if electrical gremlins are erasing PCM data?
In any case I will look for the OBD2 Compliance sticker. Wish I would've known to use these programs when I had my original PCM in.
EDIT: I also know for a fact that 1996 was the starting year for OBD2 compliance therefore "A COMPLIANCE STICKER" or certification may not have yet been available to any car maker..... yet Ford followed the OBDII standard in developing the 1995 3.8L Ford Windstar because it requires no special code reader. A generic plain featured "code reader only" with OBD2 compliance can read from this PCM.
Old 07-01-2009, 05:03 AM   #15
Well, I don't know what the deal is really. A moderator in another forum has a sticky up saying ALL years Windstar are OBD2 compliant, but the sticker doesn't say it under my hood. I will look at the PINS tomorrow and see if ALL of them are there too. I found out thats another way to tell.
Still, again it responds to OBD2 programs/datalogger.
Magden Linux OBDII & Gauge, Performance Software Fiberoptic Mp3Car Blog Talk 6 09-14-2009 04:56 PM
RR's Commitment to the Mp3Car forums guino Road Runner 0 06-05-2009 04:58 PM
Really bad software jimisbell GPS 0 05-02-2009 11:39 PM
obdII software for Ipaq (pocked PC Media 2K3) Mage Engine Management, OBD-II, Engine Diagnostics, etc. 2 09-21-2004 06:34 PM
