06-28-2009, 04:57 AM
#1
ELM 327 and Citroen c4
Hello. I have a problem. I have a elm 327, i connect it to my c4 from 2006 and the soft says cannot connect unknown protocol. Can somebody tell me what to do?
Thank you!
06-29-2009, 12:12 PM
#2
VENDOR - ScanTool
Try STNTerm
Thank you!
Download STNTerm, then send the following commands:
ATZ
ATH1
ATSP00
0100
011C
Right click in the window, "save as" or "copy", and post here. Then, repeat with:
ATZ
ATH1
ATSP3
0100
011C
Best regards,
Vitaliy
— Did you know that MP3Car sells OBD-2 interfaces? Get your ElmScan 5 Compact for only $64.95!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
06-30-2009, 07:58 AM
#3
And what are those command for? What is the purpose of this program?
06-30-2009, 12:37 PM
#4
VENDOR - ScanTool
The program is a virus, its purpose is to steal your private information, post it to our servers in Somalia, and then set your PC on fire.
I'm kidding. The software is a terminal that lets you talk directly to the ELM327 and your car. The first set of commands sets the protocol to "Automatic", the second set sets it to "ISO9141". Then we send two OBD requests, which ask the vehicle which PIDs are supported, and what OBD system it has.
Vitaliy
06-30-2009, 02:07 PM
#5
Does the same commands work for FIAT Grand Punto with 1.3 MJD diesel engine?
I get the same error as unknown protocol.
06-30-2009, 02:30 PM
#6
DigitalVampire, what's the model year and where (which country) do you live?
06-30-2009, 07:24 PM
#7
VENDOR - ScanTool
The same commands should work, but I doubt that your vehicle is EOBD compliant (unless it's MY2004+ car).
See this page for a more in-depth explanation:
How do I know whether my car is OBD-II compliant?
Best regards,
Vitaliy
Reason: typo
08-30-2009, 05:26 PM
#8
I have the same probelm unknown protocol.
I make this test
ATZ
ATZ
ELM327 v1.3a
>ATH1
ATH1
OK
>ATSP00
ATSP00
OK
>ATSP00
ATSP00
OK
>0100
0100
SEARCHING...
UNABLE TO CONNECT
>011C
011C
SEARCHING...
UNABLE TO CONNECT
ATZ
ATZ
ELM327 v1.3a
>ATH1
ATH1
OK
>ATSP3
ATSP3
OK
>0100
0100
BUS INIT: ...ERROR
>011C
011C
BUS INIT: ...ERROR
I use this device
http://cgi.ebay.com/ebaymotors/AL-OB...=p4506.c0.m245
I had FIAT IDEA ELX 1.4 2007 from BRAZIL.
I try test with other software but not work too.
Thx
EMERSON VIER
08-31-2009, 12:42 AM
#9
VENDOR - ScanTool
I'm afraid that either your vehicles is not EOBD compliant, or the tool is defective.
Can you look at your diagnostic connector, and tell us which pins are populated?
Vitaliy
08-31-2009, 02:53 AM
#10
Brazil does not use OBD2 or EOBD. No rules there yet.
08-31-2009, 06:37 AM
#11
Vitaliy
Vitality check on the car?
Thx
EMERSON VIER
08-31-2009, 06:48 AM
#12
p2psmurf
Are you from Brazil?
Thx
EMERSON VIER
08-31-2009, 08:08 AM
#13
No, I'me not from Brazil.
But that fact has got nothing to do with the validity of the answer.
From which country are you? That would help identifying to which standard the car should comply.
How many oxygen sensors does the car have in front of the cat and how many behind the cat?
08-31-2009, 09:48 AM
#14
p2psmurf,
If you are from Brazil, more easy for me ask on Portugues(my english is terrible).
I live BRAZIL, I found one paper about FIAT IDEA on Italy and show the picture "EODB", but I know its the same on BRAZIL, here many car use ODB or ODBII.
Thx
EMERSON VIER
08-31-2009, 09:57 AM
#15
My Portugues doe not exist at all.
So, how many oxygen sensors (Lambda-sensors) does your car have?
Oxygen sensors are placed in the exhaust, in front and behind the catalytic convertor.
That this Fiat in Europe has EOBD does not mean it has it in Brazil. It is not required by law.
What's the engine code? Should be on a plate in the engine bay and looks like this:
188.A9.000 or 843.A1.000.
| Thread Tools |
| Display Modes |
Linear Mode
