Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 07-10-2009, 10:54 AM   #1
sonicmule is an unknown quantity at this point
VW / Audi 1.8 20vt Map Sensor reading?
Hi there
I'm working on a project for windows mobile that reads the sensor values via an elm327 bluetooth dongle. I've made a boost gauge and wanted to test it out on a mates Seat Ibiza 1.8t as he has a boost gauge fitted. After querying the ecu for supported PIDs, I found that it doesn't support a MAP sensor reading :-(
I've been told its possible to read this using VAG-COM.
Does anybody out there know if Scanguage is capable of reading the MAP sensor PID and what it does to read it?
Cheers
Simon
sonicmule is offline   Reply With Quote
Old 07-10-2009, 12:41 PM   #2
p2psmurf is an unknown quantity at this point
If supported you can use pid $43 Absolute Load value.
100% is 1 bar absolute = atmospheric pressure.
200% is 2 bar absolute = 1 bar boost, etc.
According to SAE J1979 this pid must be supported.
p2psmurf is offline   Reply With Quote
Old 07-13-2009, 04:09 AM   #3
That's very interesting, where did you find that out?
Seeing as absolute load value goes up to 25,700%, I guess that will do it.
Thanks, I'll give that a go.
Old 07-20-2009, 03:20 PM   #4
No luck, the absolute load value PID isn't supported by the ECU.
I suppose if I new anything about how VAG-COM works, I could get at it that way.
Testers needed: VW, AUDI, BMW stock headunit USB adapter ! jbors Input Devices 96 11-30-2006 08:16 PM
2003+ VW AUDI BENTLEY MB BMW PORSCHE TV activator autosvs LCD/Display 4 01-06-2006 08:53 PM
98 audi a4 1.8 t quattro (good or bad?) Ski85 Newbie 2 12-24-2005 02:18 AM
Delorme Street Atlas 05 quick review cash_Money GPS 7 12-13-2004 08:31 PM
EPIA 800 in a VW Jetta 1.8 TURBO samc Show off your project 17 10-27-2003 07:18 AM
