Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 07-13-2009, 07:46 AM   #1
sonicmule is an unknown quantity at this point
Sample fault code output required
Just wanted to know if anyone has any sample data from a mode 3 request trobule codes function.
I don't have access to a car with the MIL lamp on at the moment and I would like to get my head around how these codes are interpreted. The more fault the better!
Cheers
Simon
sonicmule is offline   Reply With Quote
Old 07-13-2009, 08:57 PM   #2
VENDOR - ScanTool
Vitaliy is on a distinguished road
Cheers
Simon
Here's sample output from an ElmScan 5, connected to the ECU Sim (CAN):
Code:
ELM327 v1.3a >ath1 OK >03 SEARCHING... 18 DA F1 10 10 0E 43 06 01 00 02 00 18 DA F1 10 21 03 00 43 00 82 00 C1 18 DA F1 10 22 00 00 00 00 00 00 00 18 DA F1 18 04 43 01 01 01
What are you using for development?
Best regards,
Vitaliy
— Did you know that MP3Car sells OBD-2 interfaces? Get your ElmScan 5 Compact for only $59.95!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
Vitaliy is offline   Reply With Quote
Old 07-14-2009, 01:59 PM   #3
Aberk is an unknown quantity at this point
go unplug your O2 sensor. It shouldn't take long after that.
Aberk is offline   Reply With Quote
Old 07-14-2009, 04:15 PM   #4
Mod - OBDII GPS Logger forum
chunkyks is on a distinguished road
Or, possibly less destructively, leave your fuel cap off for a couple minutes.
Gary (-;
chunkyks is offline   Reply With Quote
Old 07-17-2009, 05:38 AM   #5
sinclairvital's Avatar
sinclairvital is on a distinguished road
Fault Codes
Hi,
I have written and posted a document on my web site to give a few examples and explanations of fault codes responses read from real vehicle ECU's with the OBDKey vehicle interface unit.
http://kbmsystems.net/files/Engine%2...h%20OBDKey.pdf
The tests were carried out on Ford ECU – CAN based OBD-II protocol - and
VW Golf, Subaru WRX, Mitsubishi Evo 8, Triumph Motorcycle ECUs– ISO 9141 based OBD-II protocols- with the OBDKey version 1.10K
Sinclair
sinclairvital is offline   Reply With Quote
Old 07-17-2009, 06:06 AM   #6
p2psmurf is an unknown quantity at this point
Nice examples Sinclair.
Do you also have examples of mode 0A?
p2psmurf is offline   Reply With Quote
Old 07-17-2009, 10:31 AM   #7
Sinclair, to answer your question, mode 0A is a new mode for reading DTC's.
These DTC's are called "Permanent" and can only be reset by the ecu and not by a scanner. Mode 04 has no effect on these DTC's.
The mode is defined in the 2007 version of SAE J1979 and ISO 15031, so I am amazed you never heard of it. Other programs like VCDS (or Vagcom as it was used to be called) and the Silver Scanner from the Dearborn group already support this mode in their software. Even wikipedia has already heard of it.
See: http://engineers.ihs.com/document/ab...QIACAAAAAAAAAA
and: http://en.wikipedia.org/wiki/OBD-II_PIDs
Old 07-17-2009, 12:54 PM   #8
Mode 0A
Thanks for enlightening the group! Of course I had heard of it.... 2007 was a long time ago
Do you have sample commands and responses then? Care to share?
Cheers
Sinclair
Old 07-17-2009, 01:03 PM   #9
Strange, below is the message I received, are you trying me out or what?
"Mode 0A? I've only used modes 1 to 9 with OBD-II, so where would I find out more about mode 0A?
I have used the EOBD commands, SSM commands and VAG / KW1281 commands, but I don't recall mode 0A! Can you enlighten me please?
Sinclair "
I've got just one question left, Why is this mode still not supported by the majority of the programs which you have to pay money for.
I would expect an up-to-date program for the money they charge. Makes you wonder if any of the other new additions are supported.
Old 07-17-2009, 05:21 PM   #10
Could it be due to lack of sample data?
Ford Transit Mk 5 Fault code reader maltesefalcon Engine Management, OBD-II, Engine Diagnostics, etc. 0 12-12-2008 10:08 AM
sample for in-car OBDII output on 20x4 Telek Engine Management, OBD-II, Engine Diagnostics, etc. 35 07-23-2007 12:51 PM
XMDirect Digital Audio Output ? Retsaoc General Hardware Discussion 13 10-11-2004 09:10 PM
