Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 07-17-2009, 06:00 AM   #1
vptcr is an unknown quantity at this point
n00b here :) One question pls
Really appreciate if you can help answer my following question:-
* Can OBDII be used to 'Measure' the tailpipe emissions (CO2, CO, HC) in realtime?
* If it does not, is there a way to deduce the emissions value from the vehicle in realtime?
Please consider giving me some pointers. Thanks much.
vptcr is offline   Reply With Quote
Old 07-18-2009, 05:56 PM   #2
VENDOR - ScanTool
Vitaliy is on a distinguished road
1. Not directly, no.
2. You may be able to guesstimate CO2 the same way people guesstimate MPG. The simplest way is to measure the airflow and assume an ideal burn.
Vitaliy
— Did you know that MP3Car sells OBD-2 interfaces? Get your ElmScan 5 Compact for only $64.95!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
Vitaliy is offline   Reply With Quote
Tags
obdii
Ipod / usb recognition question psychotic Newbie 0 05-17-2008 06:10 AM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 01:08 AM
n00b question alert! How to power a min-ITX system? RDaneel Power Supplies 16 12-11-2003 01:24 PM
Question on sound... seth98es Newbie 5 11-28-2003 06:26 PM
n00b question: Regarding CarPuters g33kb0y00 Newbie 4 11-20-2003 02:45 PM
