07-22-2009, 10:29 PM
#1
distance travelled
i want to build a device that i can connect to the obd2 interface, to enable me to record the distance travelled, i know i can see this by reseting the trip counter but, but i want to seperate business from pleasure. i was looking at maybe using a picmicro, having two push button switches, one for business and one for pleasure, when i get in the car i press which ever button and it will record the mileage. not sure how i would retrieve this info????
all help appreciated
07-23-2009, 09:20 PM
#2
VENDOR - ScanTool
If this is for tax or business purposes, you also need to be able to enter a short description of the trip. E.g., "meeting with a client", "checking rental property", etc. No?
— Did you know that MP3Car sells OBD-2 interfaces? Get your ElmScan 5 Compact for only $64.95!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
07-24-2009, 04:16 AM
#3
For tax purposes there are many existing solutions.
See: http://www.accredis.co.uk/
07-24-2009, 04:35 AM
#4
licensed to kill
afiak, you can't get this from standard obd-II. I have written code to keep track of that via GPS though. However, it's not as accurate as getting it straight from the car...
LinuxICE - because my car already has enough windows (and because I like speed).
LinuxICE2 beta2 is released!!! get it now!
Follow OpenICE development
07-24-2009, 07:55 PM
#5
VENDOR - OBDPros
You could derive this by requesting the speed from OBD II every minute (pid 0d) and continually adding the distance travelled in that interval. distance travelled would be speed/60 in this case added every minute.
for greater accuracy request the speed every second and integrate...
Paul
07-24-2009, 08:09 PM
#6
Terminal flasher
my vehicle maintenance plugin for RR does this. You have 3 mileage calculators. Total, trip, and waypoint calculation. All thats needed is a gps connection to RR. If you wish to do something standalone yourself, i can share my code for distance calculation
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
07-26-2009, 12:30 PM
#7
odometer
this info is allready computed by the car, it must be doing this via the information from the vehicle speed. the accredis is what i am trying to do but without the information being sent to various servers. No it is not for tax purposes, it is purely for my own information. I think the idea of polling the can bus to request the speed once a second, for the duration of the journey maybe an idea.
07-26-2009, 05:36 PM
#8
North of the land of Hey Huns
Speed is usually read into the ecu as pulses from a magnetic pickup in the transmission. If you count the pulses not only do you get speed but you get 100% accurate measurement of how often the wheels have turned. Deriving distance from speed is inaccurate but the more samples per second you get the more accurate it is.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
07-27-2009, 04:06 AM
#9
VENDOR - ScanTool
Based on my experience, requesting speed over OBD-II and integrating is an extremely accurate method of measuring the distance.
Vitaliy
| Thread Tools |
| Display Modes |
Linear Mode
