Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 07-23-2009, 09:42 AM   #1
sonicmule is an unknown quantity at this point
How should I calculate fuel range
Hi all
What should the estimated range based on remaining fuel be calculated on?
Should it be on current MPG, this will go up and down as the MPG goes up and down and will be zero when at rest.
Or, should it be worked out using average MPG, this wont change a lot and if you work out that you have 200 miles left to go and then drive like an idiot, you're not going to get any where near 200 miles.
Any thoughts
cheers
Simon
sonicmule is offline   Reply With Quote
Fusion USB I/O Board - What type of sensors would you like to see? 2k1Toaster FB Sensors 100 10-05-2009 09:26 PM
Milage plugin - trip meter and fuel consumption festy RR Released Plugins 245 06-07-2009 11:31 AM
18 mile (10KM) range Bluetooth device... rijndael Wireless Communications 5 07-05-2007 03:54 AM
Bug Reports 1.09 frodobaggins FrodoPlayer 279 10-22-2004 11:24 PM
Anyway to calculate wifi antenna range? bizahh General Hardware Discussion 9 01-01-2004 03:59 PM
