Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 07-27-2009, 11:40 AM   #1
lucal is an unknown quantity at this point
MAF value
Hi
I would like to know the possible values (range) of the MAF OBDII parameter (gr/sec) for a standard diesel engine.
Moreover, can someone help me to find the right formula to calculate the consumption value using the MAF parameter?
Luca
lucal is offline   Reply With Quote
Old 07-27-2009, 12:14 PM   #3
p2psmurf is an unknown quantity at this point
You can't calculate it for a diesel using the MAF-value.
The amount of air going into the engine is not restricted, it's the amount of fuel that's restricted.
p2psmurf is offline   Reply With Quote
OBDMPG - MPG OBDII Plugin for RR [NEW! 6-12-09] mezz64 RR Released Plugins 377 11-21-2009 03:03 AM
Review: TouchScan OBD-II Software mezz64 The Review Palace 18 10-26-2009 08:53 PM
Beginning of an Automatic Climate Control System, all juiced up on Fusion h3rk Fusion Brain 219 10-13-2009 04:07 PM
MAF NO DATA Problem chunkyks OBDII GPS Logger 8 06-28-2009 04:27 PM
Mass Air Flow Sensor h3rk FB Sensors 5 12-16-2007 04:15 PM
