OBD 11 on a Smart ForTwo
I have a Smart ForTwo, 2003, 700cc model. A few weeks ago the engine started to run on 2 cylinders and the dashboard management light came on.
I have done a few checks but want to see what caused the management light to show (still on) before going further. I suspect a piston ring at this stage as it is a common fault and the oil had run below minimum.
My problem is trying to get a diagnostic reader or software for my laptop that reads Smart. I have read that every car after 2001 in the UK has the same protocol but these Smarts may be a law to themselves. After all, you need to take off the rear bodywork to change the lower 3 spark plugs (there are 6)......
I do have a USB KKL lead (USB to OBD11) that I have used my VAG-COM software with but VAG-COM refuses to look at the Smart.
Can anyone help or even point me to a decent code reader for less than £100? Thanks in advance.
