Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 08-10-2009, 02:10 PM   #1
nelissen is an unknown quantity at this point
PLX devices
Has somebody tried the plx devices boost and oiltemp sensor modules and connected it to his carpc ????
I would like to know does it work OK ???
Eric.
nelissen is offline   Reply With Quote
Old 08-12-2009, 02:09 PM   #2
Eric.
Nobody ?????
Old 08-12-2009, 10:51 PM   #3
NSFW is an unknown quantity at this point
I have their AFR sensor in my car, and have written some code to interpret the data. It's been baked into RomRaider and SSM Suite (http://www.romraider.com/ and http://www.codeplex.com/ssm) so if you have a Subaru you're in luck. If not, they're both open source so have at it. It should be really easy to add support for other sensors - just a few lines of code to do the conversion to the appropriate units.
NSFW is offline   Reply With Quote
Old 08-13-2009, 01:47 PM   #4
Thank you for your answer, i have a Evo.
I want to use the boost and oiltemp because i dont like some additional gauges on the dash ore somewhere else.
FCC Ok's White Space Devices Kardain Wireless Communications 3 11-12-2008 12:10 AM
Control devices via LPT and Bluetooth Towar Software & Software Development 10 08-25-2008 12:51 PM
Too many USB devices Dragonknell911 General Hardware Discussion 29 02-18-2006 04:50 PM
Can we get a forum devoted to input devices? CA 3000GT Mp3car Forum Suggestions/Comments 16 01-27-2003 03:40 AM
