Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 09-01-2009, 01:18 PM   #1
Aberk is an unknown quantity at this point
Number of cylinders?
Is there a reliable way to determine the number of cylinders in a car using only OBD II data? I am thinking of using the number of O2 sensors, but that doesn't seem reliable on some older models as they may not have as many.
Aberk is offline   Reply With Quote
Old 09-01-2009, 02:17 PM   #2
p2psmurf is an unknown quantity at this point
4-cylinder BMW's have 2 O2-sensors in front of the cat.
Older 6-cylinder BMW's only have 1 O2-sensor in front of the cat.
Some V12's have 2 O2-sensors in front of the cat, others have 4.
How do you think you can determine the number of cylinder's?
Diesels (4, 6, 8 cyl) have none, 1 or 2 O2 sensors.
Again, how do you think you can determine the number of cylinder's?
p2psmurf is offline   Reply With Quote
Old 09-01-2009, 03:04 PM   #3
I thought this would be the case with O2 sensors. That's why I asked if there was any other thoughts.
Old 09-01-2009, 04:47 PM   #4
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
The best method would be decoding the VIN, but it's manufacturer specific so would take a bit of work. Fuel trim could give you a hint but it's a lot like the O2 issue.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is online now   Reply With Quote
Old 09-01-2009, 08:46 PM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Why don't you just open the hood and count the number of spark plugs or spark plug wires?
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-01-2009, 08:51 PM   #6
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Seems the most logical to me.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 09-01-2009, 10:13 PM   #7
bratnetwork's Avatar
bratnetwork is an unknown quantity at this point
use the streaming obdII data to see how many injectors are firing, or how many cylinders it is monitoring for misfire. you will obviously need obd software that can monitor live data and not just read codes.
bratnetwork is offline   Reply With Quote
Old 09-02-2009, 10:05 AM   #8
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
this method has worked flawlessly for me, though, i think desiels use glow plugs(no spark plug wire?), so you might need to count fuel lines, or something.
soundman98 is offline   Reply With Quote
Old 09-02-2009, 10:10 AM   #9
Good point about the diesel. I didn't think about that at all, obviously....
Of course my method of counting plug wires would be inaccurate if a motor happens to be missing a plug or plug wire for some reason, such as removing them due to a problem in a certain cylinder, possibly.
Old 09-02-2009, 11:13 AM   #10
soundman98's Avatar
after you said that, i remembered that in at least the mid 90's--i am not a engine guy, so it could have been earlier/later, ford had a inline 4 cylinder motor that actually had 8 spark plugs, so counting the wires might not always be the best option either...
i guess the only reliable way would be to decode the vin, or, in case the engine was swapped to a different one at some point, learn your motor good enough to just know what it has.
Old 09-02-2009, 11:52 AM   #11
Decoding the VIN is probably best, I agree.....
As long as the vehicle has the original engine. A Mazda Miata/MX5 or Ford Ranger with a 302 conversion, for example, would have a different engine than the result of the VIN decoding would reveal.
And there are a lot of vehicle/engine combinations that make swapping to a bigger motor with more horsepower (or to a smaller more fuel-efficient motor) a relatively easy operation for a shadetree mechanic.
Old 09-02-2009, 10:33 PM   #12
Superduck's Avatar
Superduck is on a distinguished road
However, since we're talking OBDII, it'd have to be a modern engine, and to do such a swap, you'd require the PCM matching the engine, therefore it'd still report that VIN (I'm only assuming the OBDII reports the VIN) that matches the engine, therefore it'd say the proper # of cylinders. I've never done any OBDII decoding, so I couldn't be sure. There are codes for Cylinder #x misfire, etc. Though the only codes I know are the actual trouble codes, therefore will only show up when there's a problem.
Good luck with that. I'm sure someone that's done some OBD programming would know. Maybe check the Megasquirt forums?
Cheers,
Kris
How Much Horsepower Can I have And Still Go To Heaven?
Superduck is offline   Reply With Quote
Old 09-03-2009, 06:54 AM   #13
But that's an idea....
If an OBD reader would report a misfire on cylinder #X, you could, in theory, remove a plug wire and get the trouble code for the misfire and you have a cylinder number.
However there is still the potential that you would have to remove each plug wire to get to the highest cylinder number.
Besides, if you're opening the hood to remove a plug wire, then you can just count them and be done, too.... Unless, of course you have a diesel, was pointed out previously.
Old 09-03-2009, 10:10 AM   #14
If you want to damage the catalyst, then be my guest and remove spark plug wires.
Catalyst have a problem with fuel burning in the exhaust.
Release new phoco integration preview Robby BMW Road Runner 544 09-12-2009 06:29 AM
JIMI HENDRIX - FRAMED CD - NUMBER 2 of a very limited amount....... m2rv h Classified Archive 1 07-03-2005 05:46 PM
Remove song number in database? tmar89 Media Engine 1 02-25-2005 02:45 PM
ME 2.0 Official Bug Reports phat_bastard ME Archive 67 01-31-2004 07:27 PM
Error #91 SiGmA_X ME Archive 18 01-08-2004 10:40 PM
