Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 09-21-2009, 04:56 PM   #1
obstacleman is an unknown quantity at this point
Power off OBDLink with Fusion Brain
All,
I am thinking of trying this out and wanted to know if anyone one had tried it.
I have the OBDLink from scantool but it draws constant power. I was thinking of buying another (connection cable and cutting it up. Adding one of the fusion brain relays to it and having it turn on when I load centrafuse. I want to be able to leave it plugged in without draining my battery.
I will need to order in a fusion brain but I did not want to just do that without much purpose.
Any thoughts?
obstacleman is offline   Reply With Quote
Old 09-21-2009, 07:46 PM   #2
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
It should run off your PSU just fine.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 09-21-2009, 08:25 PM   #3
justchat_1 will become famous soon enough
Just curious how much of a power draw are you measuring?
I know with my obd reader (knockoff band) theres only 1Leds worth of power draw when the computer shuts off. Vehicle power powers the chip but the standby pin is tied to usb power.
openMobile - An open source C# Front End
- Currently Recruiting Developers -
Available for download on sourceforge
justchat_1 is offline   Reply With Quote
Old 09-21-2009, 09:26 PM   #4
Curiosity's Avatar
I have one of those little silver aluminum box knockoff ones. Just plugged into the car it uses 50mA and gets quite warm. Pin 16 on the OBD-II connector or pin 9 on the DB9 (check and make sure). Snip it and run a new wire from the DB9 side to anything. ACC, IGN, PSU output.
Old 11-12-2009, 07:59 AM   #5
Moysie's Avatar
Moysie is an unknown quantity at this point
Quote: Originally Posted by obstacleman View Post
All,
Any thoughts?
You can use a standard 12V automotive relay for this, you dont need to buy a fusion brain.
With my method the scantool would power up when you turn on the ignition. Makes the design simpler to do.
I cant think of any reason at the moment why you would only want the scantool to power up once centrafuse was loaded.
My idea however would solve the battery drain problem and save a fair bit of money.
Ref to the following link where i posted info for someone else with this type of problem : http://www.mp3car.com/vbulletin/gene...y.html#1355527
Hope this help, if anyone has any questions im happy to help where i can
Regards mike
Moysie is offline   Reply With Quote
Fusion Brain -- Digital Encoder Beta Test 2k1Toaster Fusion Brain 52 09-18-2009 03:11 PM
Fusion Brain to control Toucscreen on/off kev000 Fusion Brain 2 06-25-2009 12:46 PM
USB Syncroized 5V@8A power supply POL. Now Taking Orders!!! Beehphy User Innovations 110 06-23-2009 04:22 PM
Fusion Brain and Auto HVAC. h3rk where are you? Willn Fusion Brain 4 04-17-2009 10:08 AM
Vista won't see the Fusion Brain Ineffigy Fusion Brain 6 11-26-2008 07:39 AM
