That cable has the interface inside of it, most likely a MAX232 similar to the first link I pasted. If you just make a straight-through cable, you are going to either fry your computer, or fry the ECU's diagnostic port. The ECU has single wire serial communications, using 0-3v as low, and 9-12v as high. Your computer uses (at the extreme) -24-(-3) as low, and 3-24 as high. That's not gonna play too nice.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
