Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 10-11-2009, 03:50 AM   #1
topkick is an unknown quantity at this point
Dash Command on F-650 Ford
I have the J1939 connecter ( supposedly ) and would like to know the possibility of installing any type of OBD-II scanner on the truck to use dash command
topkick is offline   Reply With Quote
Old 10-11-2009, 01:11 PM   #2
PPE
PPE's Avatar
PPE is on a distinguished road
Are you sure it's the J1939 connector? Can you post a picture? The last F-650 I saw (model year 2006 I think - it had the Cat engine) had a regular looking OBD-II style 16-pin connector. Unfortunately, I did not have my laptop with me at the time, so I have no idea what OBD-II protocol it supported (if any).
Brian @ Palmer Performance Engineering, Inc.
http://www.palmerperformance.com
PPE is offline   Reply With Quote
Old 10-12-2009, 12:43 AM   #3
this is the connecter and its 2008 model
I really would like to have some sort of info on the carputer
Old 10-12-2009, 02:02 PM   #4
VENDOR - ScanTool
Vitaliy is on a distinguished road
Yup, that's a J1939 connector. Can you pop the dust cover?
Sadly, J1939 is fundamentally incompatible with OBDII. Hardware is the same (CAN), but the way messages are encoded and the way communication is structured, are completely different.
Vitaliy
— Did you know that MP3Car sells OBD-2 interfaces? Get your ElmScan 5 Compact for only $59.95!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
Vitaliy is online now   Reply With Quote
Old 10-13-2009, 10:16 AM   #5
VENDOR - OBDPros
michbound is on a distinguished road
There are some low cost J1939 solutions available PM me and I can send you the info
You could also look at Autotap but they are expensive!
Paul
OBDPros Scantool
michbound is offline   Reply With Quote
Old 10-13-2009, 10:44 AM   #6
Aberk is an unknown quantity at this point
I have encountered connectors like this in some heavy duty Chevy trucks that are actually J1708 in a J1962 connector. That took awhile to figure out.
Aberk is offline   Reply With Quote
Old 10-13-2009, 12:22 PM   #7
VENDOR - ScanTool
That's odd. Do they at least use the same CAN pins (6 & 14)?
Vitaliy
Old 10-13-2009, 12:49 PM   #8
Vitaliy
J1708 isn't CAN, but they used the J1850 pins. Which, ironically, are the same pins that are driven by our product for J1708. I.E. our device can be configured for heavyduty or OBDII and the same pins on our cable are used for J1708 and J1850, so all we did was change the connector and it all worked.
Old 10-13-2009, 12:50 PM   #9
VENDOR - ScanTool
Sorry, I was thinking "J1939".
CarPC Install and Audio Upgrade - Ford F550 Truck jbeletti Worklogs 1 07-31-2008 06:37 PM
closed AmgAuto Car Audio 0 03-02-2008 12:59 AM
Help on custom dash for Caddy STS Slaughterhouse Fabrication 34 12-14-2006 07:47 PM
1994 ford explorer bondo dash with lilliput :-D 1st project what u think xdjxklusivex Fabrication 11 01-02-2005 09:33 AM
In dash or Not in dash that is the question belezeebub Fabrication 15 12-10-2004 06:18 PM
