Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 11-06-2009, 10:58 AM   #1
jonti007 is an unknown quantity at this point
elm327 setup
I have an ELM327 but I am having difficulty in setting it up, yes i have a disc that came with it but no matter how carefully I follow the sparse instructions i am getting nowhere.
Can anyone help please??
jonti007 is offline   Reply With Quote
Old 11-07-2009, 01:32 PM   #2
VENDOR - ScanTool
Vitaliy is on a distinguished road
You get what you pay for. If you bought an OBDLink or an ElmScan 5, you would have received:
  • A tested, working product
  • Easy to follow Quick Start Guide
  • Installation CD with diagnostic software and utilities
  • Best support in the industry
If your hardware is in working order, we may be able to get you up and running with the ELM327. Can you provide more details about the problem?
Vitaliy
— Did you know that MP3Car sells OBD-2 interfaces? Get your ElmScan 5 Compact for only $64.95!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
Vitaliy is offline   Reply With Quote
Old 11-17-2009, 04:10 PM   #3
sinclairvital's Avatar
sinclairvital is on a distinguished road
Why not start by describing the problem you are having and what you have set up so far?
Include the vehicle details too.
sinclairvital is offline   Reply With Quote
Old 11-18-2009, 04:32 AM   #4
I have Peogeot 406 HDi (90) 2001 I have had conflicting advise as to whether this model of car is OBD2 compatable with ELM327. If it isnt compatable then it is not the interface or software that is at fault, but I dont know for sure
Old 11-18-2009, 06:34 AM   #5
p2psmurf is an unknown quantity at this point
Peugeot diesels are not compliant, and never will be compliant to OBD2, because the car has never and will never be sold in the USA.
It does not have to comply to the European version (EOBD) until 2004. So, it probably just does not comply.
p2psmurf is offline   Reply With Quote
Old 11-18-2009, 08:14 AM   #6
But a OBD2 socket is fitted to the car with 12v coming from the final pin.Why would this be???
Old 11-18-2009, 08:25 AM   #7
Socket is required by Law for PETROL cars. And it's cheaper for the manufacturer to use one type of diagnostic connector.
The presence of the connector is no guarantee EOBD will work.
pleasant experience with new setup nst6563 General Hardware Discussion 0 04-28-2009 08:22 PM
What kind of setup do you have for a PCMCIA Card? polo6979 Wireless Communications 5 04-18-2008 12:36 AM
Help with general setup Blup Newbie 0 01-11-2008 12:50 PM
Centrafuse 1.2 won't leave setup marchello2000 CF Bug Reports 4 07-03-2007 12:18 PM
How do I setup my Radio or Sat Tuner ? Which tunners work ? guino RR FAQ 0 03-20-2005 02:34 PM
