The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 08-18-2003, 08:47 PM   #1
Registered User
Sh0cker's Avatar
Vehicle: mk3 GTI VR6
My Photos: (0)
Exclamation OBD-II cables/software
Probably many of you have this up and running, but once again I'll ask you for help abut it. I'm the owner of VW Golf '95 which has that connection (as long as I know its ISO 9141-2).
Where would you recommend me to buy the converter/adapter wich connects to the computer (usb, serial, parallel, etc), OR any schematics to build one.
Also which software you recommend, I'm new in this and i dont know if the software supports all the vehicles or just a specific ones. I rather use a free one but you can post other also (there is more things online for free than you think).
Danny.
"If today was perfect, there would be no need for tomorrow."
My Car Project® ‹== !10.4" Allbrite, touchscreen, epia, 150opus, gps, wireless, sony remote [old] 128x64 Crystalfontz +double din [new]
Sh0cker is offline   Reply With Quote
Sponsored Links
Old 08-18-2003, 11:40 PM   #2
cproaudio's Avatar
Vehicle: 97 Tacoma X Cab
My Photos: (0)
look at the manufacture date. If its before 01/96, not likely its an OBD-II. OBD-II is not manditory til 01/96. Before that date, Auto makers are not required to equip their cars with OBD-II.
NEW complete and updated My project with 100+ pics on 7-4-03
If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
cproaudio is offline   Reply With Quote
Old 08-19-2003, 02:48 AM   #3
Registered User
Sh0cker's Avatar
My Photos: (0)
I dont know what to say but I saw it in my car
Its right in my dashboard hidden behing little plastic cover.
Danny.
Old 08-19-2003, 04:05 AM   #4
_maelstrom's Avatar
Vehicle: 1996 Chevrolet Camaro
My Photos: (0)
Just because the vehicle's a 95 doesn't mean it can't have OBDII. It wasn't made mandatory til 96 but it was available on cars before that.
In this case, however, cproaudio is right. The 95 VW Golf has the J1962 16 pin diagnostic link connector, which is used for OBDII, but it doesn't support OBDII. I guess the best way to tell for sure is the car has to have the J1962 DLC and an under-hood OBDII sticker.
- Sony XAV-7W In-Dash 7" LCD
- Via EPIA 800MHz
- 256MB SDRAM
- 40GB HDD
- Targus Wireless Remote
- Win 98SE
See it Here
or Here (cardomain.com)
_maelstrom is offline   Reply With Quote
Old 08-19-2003, 09:48 AM   #5
SOBIL's Avatar
Vehicle: 95 - GM Holden - Berlina
My Photos: (0)
shhhhhh.
not that i should be telling you,
You can either buy a Seimens VAS5051 (one beast of a macheine)
or a VAG-COM with VAG-COM windows based software
VAG-COM sells its "dongles"/adapters for a fair bit
- however you can make one yourself (search DIY VAG-COM)
You can build one your self for cheaper, and the software is free. works on most efi VW's/AUDI/SKODA/SEAT, not some early transporters. highly recomended.
you know the most expensive part of the DIY is the dame OBD style plug.
they cost a packet.The cheapest i've seen is $35au.
it is also possible to splice the wire behind the dash as on a golf 3 there is only a "K" wire which requires little electronic protection, apposed to the newer CAM bus which cannot easily be spliced. This will make your mounting easier I would think as you could mount all your wiring behind the dash. (watch out for your heater control matrix as they fequently break when removed)
http://iamnot.azn.nu
SOBIL is offline   Reply With Quote
Old 08-20-2003, 07:51 AM   #6
chut's Avatar
Vehicle: 2000 BMW M Roadster
My Photos: (0)
This something I will do eventually also.
I found this on the site www.obdII.com. It is a direct quote from their webpage. I think this will tell you which pins you need to wire up to your serial plug in order to use the home made plug. "ISO 9141-2--The connector should have metallic contacts in pins 4, 5, 7, 15, and 16." I believe this means these are the only pins that are actually needed to be connected to your serial port in order for the software to work. I don't know for sure, because I haven't tried it. If anyone here has, I would appreciate it if you could let me know.
chut is offline   Reply With Quote
Old 08-20-2003, 07:56 AM   #7
chut's Avatar
My Photos: (0)
Build one yourself.
Hi!
can you tell me where I would find the plug end and pins so that I could build one myself? I already have a long serial cable.
Old 08-20-2003, 08:15 AM   #8
MySQL Error
jcdillin's CarPC Specs
jcdillin's Avatar
Vehicle: 2002 Dodge Ram 1500 Quad Cab
My Photos: (3)
Just go to http://www.obddiagnostics.com they have the software for free and they sell partial or complete kits.
Quote: Originally Posted by chut
Hi!
jcdillin is offline   Reply With Quote
Old 08-20-2003, 05:56 PM   #9
Vehicle: 1998 Nissan Altima
My Photos: (0)
you can also check out www.autotap.com
Its $200.00 for the hardware and software package. The interface is the nicest that I have seen. But for the price it should be.
SolacE is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
