The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 09-04-2003, 11:03 PM   #1
Hosting Guru
Vehicle: '96 BMW M3 Wifey-Moibile: '04 Lexus IS300
My Photos: (0)
New Project: Linux ODB-II SBC
Ok,
Since I'm basically broke at the moment and the mp3car project had to be side lined and I've been forced to sell most all of my hardware I want to work on this small project. I'm looking for suggestions and possibly help?
Purpose: Fetch ODB-II junks from car
Interface: Push Buttons of some sort
Display: small lcd, maybe 4 line?
System: Small sbc with a small CF drive running Linux
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=4615
ODB-II Interface: serial or USB preferably serial
I'd like to have this as a seperate "system" that could easily be mounted on the gauge pod to display odb-II info and maybe have a 'scroll wheel' or something to that effect that would scroll through the output types... anyway just a REALLY vauge description... anyone interested in something similar?
-- WireSix, Inc. --
MP3Car Lives Here!
W6-Ryan is offline   Reply With Quote
Sponsored Links
Old 09-05-2003, 01:35 PM   #2
Vehicle: 2002 Subaru Impreza WRX
My Photos: (0)
You probably don't need that kind of power (the SBC) to do OBD2 display. This is made for Subarus but it does read OBD2 (as well as Subaru Select Protocol), and there really isn't that much to it.
TyrannoSullyRex is offline   Reply With Quote
Old 09-05-2003, 01:37 PM   #3
SiGmA_X's Avatar
Vehicle: 1993 BMW 325is
My Photos: (0)
Know about anything for OBDII to USB?
1993 BMW 325is - 15.2sec
SiGmA_X is offline   Reply With Quote
Old 09-05-2003, 01:44 PM   #4
My Photos: (0)
Like this?, it includes software, I don't how much just the cable is.
Old 09-05-2003, 02:54 PM   #5
Hosting Guru
My Photos: (0)
Hmm I like that think made for scoobs... but I'd like mine to do logging, etc and then be able to dump it off of the unit easily... thats why I would use the CF
-- WireSix, Inc. --
MP3Car Lives Here!
Old 09-05-2003, 04:08 PM   #6
My Photos: (0)
It's supposed to do logging in future versions. It has a small chip that you change out to update the version. Plus it has a strip on the back of it that has outputs for shift lights, water injection, etc. as well as inputs for other gauges not supported by the factory ECU. There is a big strip of outputs that are unused at this time that are supposed to be used for logging. Right now if I want to log I use this.
Old 09-05-2003, 04:41 PM   #7
Vehicle: 2004 Jetta GLS TDI (biodiesel)
My Photos: (0)
techm3: You should consider using a small microprocessor like the BasicX for your project. You would need a protocol converter to convert OBD-II into RS232. The BasicX is more then capable of controlling a few buttons and displaying some info on an LCD. If you have programmed in Visual Basic before then it’s not too hard to program the chip. www.basicx.com
Zip-Lock is offline   Reply With Quote
Old 09-05-2003, 05:02 PM   #8
Hosting Guru
My Photos: (0)
VB, C, C++, JAVA it all works for me
-- WireSix, Inc. --
MP3Car Lives Here!
Old 09-05-2003, 07:44 PM   #9
My Photos: (0)
I'm working on a Linux car computer, too, and intend to work an OBDII interface in later, so I'm very interested in your project. I'm writing my project in Perl, so naturally I hope you choose to, too. (It's quite C-like!)
Do you intend to leverage FreeDiag (http://sourceforge.net/projects/freediag/), ScanTool (http://sourceforge.net/projects/scantool/), or any other projects?
Have you chosen OBD-II interface hardware?
Mxyzpltk is offline   Reply With Quote
Old 09-06-2003, 07:50 PM   #10
Vehicle: 2003 Subaru WRX
My Photos: (0)
I have made such a device, its powered by a AM186ED microcontroller, using a full demo board so its got two built in serial ports, some flashrom for saving the embedde software on it etc. Anyways i did the entire project my self using this board and a 320x200 pixel SED1330 controlled monocrome graphics display. It currently only works with the ISO9141-2 hardware standard(almost all JAP spec cars, ie Nissan, Subaru, Toyota, etc). The ISO standard is really easy to design the hardware for because its basicly a serial link with slightly modified logic leves. Instead of the -6to-30V for a logic 1 on RS232A its +12V, and instead of +6to+30V for a logic 0 on RS232A its 0V. This is easy to convert and because you really need to optically isolate the connection anyways you can use the optoisolators to do the level shift and inversion for you. I would recomend purchaseing the ISO 9141-2 document if you are really serious. You are also gona need to learn the iirc. SAE J1978 OBDII protocal to use for communication. Basicly the SAE protocal is used ontop of the given hardware levels, ie ISO 9141-2, PWM, or VPW. Also in the very near future there will be a new standard called CAN. I would also recoment you purchase the SAE J1978 document. Both can be downloaded in PDF format for around $40 us iirc. Again this is only for ISO specific cars, so this will not work in Fords etc. I have not designed the hardware for the two other standards so im not sure how it could be done. BTW may i suggest the MAX232A chip to do your line level conversion *hint hint* if your just gona use the PC serial hardware.
Okay that was long and prob very confusing, sorry i have a hard time organiseing my thoughts on matters such as these. Anyways i wouldn't mind helping much as i am going to be porting my software to win32 soon i think so i can so a very similar thing for my Subaru WRX, its going to be a 2x16 CHAR lcd to display things such as Engine Load, EGT Temps, Coolent Temps, Boost levels(not sure if this is possible yet), etc. Good luck and i hope what i wrote was understandable.
EDIT:
Side note, if you going to be using a PIC controller or BAISC stamp type microcontroller, you had better have a dedicated CHIP to do the house keeping on the OBDII connection. You will have a VERY hard time trying to get the BAISC or PIC controller to keep on top of the strict timing requirements for OBDII. If you do decided to go this route there are IC's such as a few made by ELM that will do all the raw OBDII communication stuff for you. You can find more info on the forums at www.obdii.com.
2003 WRB Subaru WRX
99 Nissan Sentra SE Cobal Blue (SOLD)
P166 64Meg RAM
ATI All In Wonder PCI 16Meg
SB AWE32 Plug'n Play
Linksys PCI NIC
Western Digital 13Gig UATA-66 HD
5.6in Color Active Matrix TFT Screen
AloneInTheVoid
Synx is offline   Reply With Quote
Sponsored Links
Old 09-07-2003, 04:19 AM   #11
SinnerG's Avatar
Vehicle: 1998 Chevy Blazer
My Photos: (0)
I don't have anything to help with the OBDII, but I am VERY familiar with the AMD186ED board. In fact, I still have two boards. These were used for my senior project in school.
SinnerG is offline   Reply With Quote
Old 09-07-2003, 08:23 AM   #12
My Photos: (0)
Hehe, Long Beach eh? Let me guess, DeVry Long Beach... I went to the West Hills Campus. My senior project was the OBDII project last term, if you haven't graduated yet.
Old 09-07-2003, 01:15 PM   #13
SinnerG's Avatar
My Photos: (0)
I graduated a year ago (October 2002). Our class was the was the first to use that board.
Old 10-06-2003, 08:15 PM   #14
Magnezium's Avatar
Vehicle: 2002 Pontiac Trans Am WS.6
My Photos: (0)
I went to Devry in West Hills in 2001. I didn't like it. But I must say that it was a good school if you didn't care about your environment.
I working on an OBDII project for my carputer also. But it's not going to be reading error codes and what not. It's going to be linked to my GPS system to make it more acurate. Basically, I'm using the OBDII to read the speed of the car and send that to the GPS so it can track distance faster. I'm working on it, but it's going to take a while to crack the stupid GPS sdk I have. I hate compiled SDKs. Later, I plan to incorperate a 3rd screen for a full color heads-up-display to give me my GPS/Speed/RPMs/Fuel/Night Vision.
Need any help, yell.
Mg.
Just your friendly neighborhood computer specialist.
Silver/Black
Looks like new... Wanna know why they call me "Crash"?
Magnezium is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
