Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 12-28-2003, 04:32 PM   #16
dbinnc's Avatar
dbinnc
that is prolly the best feature rich software I have seen, but it is still ugly.
dbinnc is offline   Reply With Quote
Old 01-12-2004, 03:16 AM   #17
Eclipsed is on a distinguished road
Check out http://www.elmelectronics.com/ .They sell interface chips for less than $20, and only need minor($5) parts to complete.Their datasheets have schematics and alot of info too.
Eclipsed is offline   Reply With Quote
Old 01-12-2004, 03:47 AM   #18
GingerPrince's Avatar
GingerPrince
There's another option here : http://www.andywhittaker.com/ecu/obdii_hardware.htm
Plus there's also ALDL hardware (including some DIY circuits), if you have an older, non-OBDII car that you can decode.
GingerPrince
Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
Carputer Install - http://www.stuffandting.com/carputer/
CarBox Software -- http://www.stuffandting.com/carbox/
GingerPrince is offline   Reply With Quote
Old 01-12-2009, 01:59 AM   #19
VENDOR - ScanTool
Vitaliy is on a distinguished road
ElmScan OBD-II interfaces
Updating an old (but nonetheless popular) post.
Today, it is safe to say that ElmScan and other ELM32x-compatible interfaces have pretty much won the OBD-II interface war. They are by far the least expensive kind, and are supported by a host of diagnostic software.
They are the only kind of OBD-II interface offered for sale by the MP3Car store
Vitaliy
— Did you know that MP3Car sells OBD-2 interfaces? Get your ElmScan 5 Compact for only $79.95!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
Vitaliy is offline   Reply With Quote
Old 01-12-2009, 04:29 AM   #20
obdiinut is an unknown quantity at this point
in my research these www.obdpros.com were the cheapest with ELM 327 functionality
Arun
obdiinut is offline   Reply With Quote
Old 01-13-2009, 01:39 PM   #21
bemenaker's Avatar
bemenaker is on a distinguished road
I am currently working on this:
http://www.planetfall.com/cms/conten...ics-pcb-layout
I will let you know if it works. I built the PCB Sunday. I just got some of the parts I need. The calbe will be what's holding me up.
bemenaker is offline   Reply With Quote
Old 01-13-2009, 01:52 PM   #22
VENDOR - ScanTool
What kind of cable?
Old 01-15-2009, 04:06 PM   #23
bemenaker's Avatar
j1962 to 9pin dsub. I have one on order. I thought I could get the j1962 connector at a local electronics vendor but they didn't have them. The board is sitting here ready to go, I should have the cable on Monday. I will test it and post results as soon as it gets in.
Old 01-19-2009, 12:11 PM   #24
snbe82 is an unknown quantity at this point
what about something like this..? Unreliable?
(link should be good until feb 9 09)
snbe82 is offline   Reply With Quote
Old 01-22-2009, 05:28 AM   #25
VENDOR - OBDPros
michbound is on a distinguished road
Yeah these are not only unreliable but they do not support the advanced features such as
1. Ability to request a single response from the ECU - this increases the response speed of the interface
2. Ability to upgrade the firmware remotely - No possibility to get enhaced features when they are release.
3. Baud rates higher than 115K or 500K
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 01-22-2009, 10:38 AM   #26
Cool, thanks. I ordered one of yours yesterday.
Old 01-22-2009, 07:46 PM   #27
VENDOR - OCTech
mjo151 is an unknown quantity at this point
I have one from OBDPros and it works great. Tech support has also been very good.
mjo151 is offline   Reply With Quote
Old 06-17-2009, 02:50 PM   #28
sharpmusic's Avatar
sharpmusic is an unknown quantity at this point
Does StreetDeck 2 support the OBDpro OBDII interface
I have been hearing some great things about this interface but I was wondering will it work with streetdeck.
sharpmusic is offline   Reply With Quote
Old 06-17-2009, 04:34 PM   #29
VENDOR - OBDPros
Yes it will work with streetdeck
Paul
Old 06-22-2009, 06:21 PM   #30
junhe is an unknown quantity at this point
i having a mitsubishi triton,
i removed the RV meter which can show the fuel consumption, the average km/L. L/KM and how much fuel left in the tank, which OBD II is more suitable?
is that all the adapter is the same? the most important is the software?
junhe is offline   Reply With Quote
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
