Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 11-12-2003, 04:50 PM   #1
tejesh83
Cheapest OBD-II interface/adapter?
What's the cheapest way to interface into your car's ECU/OBD-II?
Is it possible to make your own adapter?
tejesh83 is offline   Reply With Quote
Old 11-12-2003, 05:05 PM   #2
tejesh83
$82 here:
http://multiplex-engineering.com/products.htm
Some good info here:
http://www.guentchev.com/OBD-II/
Old 11-12-2003, 07:41 PM   #3
swzine is on a distinguished road
Someone else posted this on another thread: http://www.scantool.net. It looks like you can buy a cable for only $25 and download the software for free. I am not sure if you need additional parts as I have not read in detail. Has anyone actually tried one of these?
swzine is offline   Reply With Quote
Old 11-12-2003, 07:43 PM   #4
Actually..I suspect you need the scan tool as well..which is a little bit more than tejesh83's post
Old 11-12-2003, 08:59 PM   #5
djrkd is on a distinguished road
why are they all serial? is there any USB scanners? my bookpc dosent have a serial port and i would like to avoid useing an adaptor.
Pontiac Grand Am
building CarPC useing BookPC and Lilliput 7 inch TS.
djrkd is offline   Reply With Quote
Old 11-12-2003, 09:11 PM   #6
tejesh83
From my reading, it looks like you need some sort of chip to decode the signal from the ecu.
The scantool kit seems to be the best deal. It comes with the cables for only a few bucks more over the multiplex. But, you do have to pay extra if you want a case for it.
The multiplex one comes in a case, but you need to get at least a serial modem cable. And, if you want to stealth it, you may need the odb cable to relocate the bulky adapter.
I've read that the chip doesn't cost much. I've also found some schematics on various sites. But I'm not sure if I'm ready to tackle such a project. I would hate to fry the ECU. Maybe a prefab is the way to go.
If you only got free usb ports, use a usb->serial adapter.
Old 11-13-2003, 12:03 AM   #7
it looks like scantool.com sells most of the parts. I'm not ready for that task either. I am good with computers, but not electronics. I'll build a bunch of them, just not from scratch
Probably worth the $80 just for the peace of mind. It would cost you more then that just for installation if you didn't do it yourself, so it's a bargain!
Old 11-13-2003, 04:09 AM   #8
RobbieIG is on a distinguished road
Here's another one. And, as you see on the page, they offer a Serial to USB adapter.
http://www.dashmatics.com/product_in...products_id=61
RobbieIG is offline   Reply With Quote
Old 11-14-2003, 09:11 PM   #9
ibewslave is on a distinguished road
I have the ScanTool and it is worth the money spent.
ibewslave is offline   Reply With Quote
Old 11-14-2003, 10:37 PM   #10
kami333
Serial is much easier to program for and a bit easier to manufacture.
kami333 is offline   Reply With Quote
Old 12-27-2003, 03:36 AM   #11
owenjh's Avatar
owenjh is on a distinguished road
Serial is a lot easyer to program, i looked at some USB stuff just to control some relays and would never go thru such a process to send a few volts
CarComputer Status: New Car & Broken (Motherboard Fried)
Owen JH | My Linux Blog | The Tech Fellows
owenjh is offline   Reply With Quote
Old 12-27-2003, 12:24 PM   #12
wi77iam's Avatar
wi77iam
I got this one mainly because the software looked better. Only $122.
wi77iam is offline   Reply With Quote
Old 12-27-2003, 12:33 PM   #13
robiewp's Avatar
robiewp is on a distinguished road
there are manufacturers of USB components (that can with a little bit of soldering become relay controls) that have all the work for you done in modules.
but in the end serial adapters and parallel port adapters are always cheaper
robiewp is offline   Reply With Quote
Old 12-27-2003, 10:19 PM   #14
dbinnc's Avatar
dbinnc
I have the scantool as well, but it was way cheaper when I got it I think.
I only wish the software was better. v2 is supposed to becoming out b4 the next ice age.
If the code was in VB, I would tackle it.
D
dbinnc is offline   Reply With Quote
Old 12-28-2003, 03:50 PM   #15
Lacoste's Avatar
Lacoste is on a distinguished road
Lightbulb BR-3 OBDII Interface
I don't see this listed here anywhere:
http://www.obddiagnostics.com/ Made by Beverly Roadman, and has it's own software that has an option for virtual gauges (one of the things I want to have displaying real-time) AND it's supported by freediag
$88 shipped includes the cable. It also supports the 3 major protocols.
Lacoste
Lacoste is offline   Reply With Quote
Advertisement Sponsored links
