The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 11-13-2003, 02:42 AM   #1
cproaudio's Avatar
Vehicle: 97 Tacoma X Cab
My Photos: (0)
More OBD-II infos
I have the Tricom scanner from Alex C. Peper at www.obd-2.com I chose the Tricom because my 97 Tacoma is not my final project. I'll be changing the vehicle sometime in the future. The Tricom will read ALL OBD-II protocols so I'm set for any type of vehicle I plan to buy in the future. I have used it to scan my friends cars ranging from Toyota 96 Tacoma (VPW) Sienna (ISO9141), Sequoia (ISO9141), Tundra (ISO9141), 2001 Tacoma (ISO9141), GMC P/U (VPW), Ford Ranger (PWM). All worked flawlessly. For some reason, Toyotas have much higher engine load and throttle position at idle speed.
here are some additional infos
There are 3 OBD-II ptotocols, VPW, PWM, ISO. If you're sure that you're gonna use the scanner for only one car, then a single protocol scanner would work for you. It'll save you some money. If you think you're gonna use it in different cars later on, maybe trading in your current car and get a different car, then you should get an all in one reader. The software is configurable to read 1 protocol (faster) or auto detect 3 protocols (slower) on initial connection.
It is safe to leave the OBD-II scanner plugged into the OBD-II port all the time. When you run the obd scanner software, the scanner sends a request to the ECU then it sends the info back to the CarPC. It's read only so it doesnt change anything to the engine computer. More info check
http://www.mp3car.com/vbulletin/showthread.php?t=16828
Update speed. When I first got my scanner going, the update speed was about once a second (software default). It was barely tolorable. It's fine for freeway driving b/c VSS, RPM dont change that much. For street, it was a bit on the slow side. When I first take off from a dead stop, it would show 0MPH, then when the screen refreshes it's showing 15MPH then 22MPH and so on. There are 2 things you need to do to increase the refresh rate, limit the data you want to view and decrease pause time between requests. Instead of sending request of all the data, request only the data you want to use such as RPM and VSS. For example, My tricom is capable of sending 40 requests per second. This means if I only send request for RPM, my RPM will take 40 readings in 1 second. That's pretty damn fast. If I send request for RPM and VSS, the refreshment will be 20 times a second Still pretty fast. If I send request for all the sensors, the refresh rate would drop down to 2 updates per second. 2 pr second is not fast but it's tolorable during normal driving. Second way is to decrease the time in between the requests. For example. If the scanner has a 50millisecond pause between requests, the scanner will send 20 requests per second. This means you'll get 20 readings per second. If you decrease the 50 millisecond pause down to 25 milliseconds you'll get 40 readings per second.
Some OBD-II scanners also clear check engine codes which I think it means they'll write to the engine computer. I feel much safer with a scanner that's read only. I dont wanna f'up my ECU. I can clear my check engine code by disconnecting the battery for 10 seconds.
Anything else I find I'll update this post.
Some fun readings
http://www.mp3car.com/vbulletin/showthread.php?t=7351
http://www.mp3car.com/vbulletin/showthread.php?t=8205
http://www.mp3car.com/vbulletin/showthread.php?t=10054
http://www.mp3car.com/vbulletin/showthread.php?t=10292
http://www.mp3car.com/vbulletin/showthread.php?t=11733
http://www.mp3car.com/vbulletin/showthread.php?t=12612
http://www.mp3car.com/vbulletin/showthread.php?t=16111
http://www.mp3car.com/vbulletin/showthread.php?t=16498
http://www.mp3car.com/vbulletin/showthread.php?t=16803
http://www.mp3car.com/vbulletin/showthread.php?t=17008
http://www.mp3car.com/vbulletin/showthread.php?t=16487
http://www.mp3car.com/vbulletin/showthread.php?t=16956
http://www.mp3car.com/vbulletin/showthread.php?t=17920
http://www.mp3car.com/vbulletin/showthread.php?t=18623
http://www.mp3car.com/vbulletin/show...ight=bmw+I-bus
NEW complete and updated My project with 100+ pics on 7-4-03
If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
cproaudio is offline   Reply With Quote
Sponsored Links
Old 11-13-2003, 06:04 PM   #2
Vehicle: 2003 Saturn L200
My Photos: (0)
wow...looks like ther are a ton of threads that should be moved!
swzine is offline   Reply With Quote
Old 12-27-2003, 12:18 AM   #3
owenjh's Avatar
My Photos: (0)
I say we sticky this, lots of good info in easy to find and read format
Thanks crpoaudio
CarComputer Status: New Car & Broken (Motherboard Fried)
Owen JH | My Linux Blog | The Tech Fellows
owenjh is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
