The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 11-13-2003, 02:27 PM   #1
00CericaRuss's Avatar
Vehicle: 2000 Toyota Celica GT-S
My Photos: (0)
iso / vag interface differences?
I'm wondering if i could use an obd II cable that works for vagcom/vw's on my toyota... anyone know?
00CericaRuss is offline   Reply With Quote
Sponsored Links
Old 11-13-2003, 02:34 PM   #2
My Photos: (0)
and if unsure, would it hurt anything if i plugged it in?
Old 11-13-2003, 03:21 PM   #3
SMKFree
liquid_smoke's Avatar
Vehicle: VW Passat
My Photos: (0)
i doubt it will work
liquid_smoke is offline   Reply With Quote
Old 11-13-2003, 06:02 PM   #4
Vehicle: 2003 Saturn L200
My Photos: (0)
When you say cable, I guess you mean the whole unit. Cause the cable's are interchangable I think, but the chip in the reader has to be the right type. I really don't know for sure though. I'm very new to all of this myself.
swzine is offline   Reply With Quote
Old 11-14-2003, 09:05 AM   #5
Vehicle: 2002 VW GTI
My Photos: (0)
Toyotas use the ISO standard, just as your VW/Audi cars. It will work.
What software do you plan to use?
I don't believe your VAG-Com software will all that useful for your toyota, as it was specifically written to interface to modules in your VW, but any generic OBD reader software should work for you.
jasonsp6 is offline   Reply With Quote
Old 11-14-2003, 10:55 AM   #6
My Photos: (0)
sweet.. thanks jason.
the reason why i was asking is because a friend of mine has vag-com, and i'd like to borrow his cable to see if my car is all good. (it can throw codes w/out triggering check engine light) so, yeah... at 50k miles, i just want the piece of mind that my baby is a-ok.
as far as software, who knows... i'll probably sit in my garage and download a crapload of them, and choose which i like the best
Old 11-14-2003, 12:05 PM   #7
My Photos: (0)
Off hand, do you know if he built his own interface cable/hardware, or if he purchased one from ross-tech when he bought the VAG-Com?
If he bought it from Ross-Tech, it will work as long as it's one of the serial cables...
ie: the twin-com or hex-com.
The Ross-Tech USB cables will NOT work with any application other than the VAG-Com one. They communicates USB via a microprocessor and custom windows driver.
If homebuilt, almost any serial ISO cable/interface should work for you.
Hope this helps.
Old 11-14-2003, 01:06 PM   #8
My Photos: (0)
I'm about 99% positive he has the serial version, and i'm also 99% positive he bought it from ross-tech.
helped quite a bit... he's already ok'd me borrowing it
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
