Quote: Originally Posted by quinxy
Could someone tell me what's required to put this EcuTek unit in a 2004 Subaru WRX STI? I'm just not 100% clear on the concept. I read the site a good bit, but still didn't get it. Are they selling a device which plugs in to the existing on board computer? Do you need to flash the built in computer in the car and then interface that to their hardware which then gets connected to your PC. Anyone know? This all sounds very cool, I'm just not sure what's required to do it.
Hi!
I too have a STi, and I have had it modified with another ECUTEK/product that actually modifies the original ECU. The power gains is really good and safe since you rely on all the std ECU-safety meassures.
The power increased from 265Hp to 320Hp(Euro/spec STi with modified exhaust).
Anyway, the DeltaDash plugs in to the same port as the subaru workshops use, the select monitor/port(ODB/port) and it works on completely stock cars as well as highly modified ones that uses the software to monitor their cars vitals...
,L-O
