The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 11-15-2003, 12:32 PM   #1
Vehicle: 2003 Saturn L200
My Photos: (0)
ECU Programming/Tuning
Does anyone know of units that accomplish both diagnostics and ECU programming? I have seen things like the Smart Tuner, the Hypertech Power Programmer, and others that can adjust performance settings to tune your car. Do these usually hook in through the OBD-II port or the modules get soldered into the ECU?
I have a 2003 Saturn L-Series, and I have know that the dealer can hook up to my OBD-II port not only for readings but also do do certain programming. I don't know if they can access performance settings, but I know they can control certain car settings like the amount of time my lights stay on after I close the door, program keyless entry remotes and other things. For some reason them refer to the OBD-II connector as a BCM, or body control module. I am assuming it's the same thing though.
It would be a lot of fun to have an all in one package.
swzine is offline   Reply With Quote
Sponsored Links
Old 11-16-2003, 07:55 AM   #2
Vehicle: 1999 Grand AM SE
My Photos: (0)
its probably proprietary technology to do all the things u mentioned since the ODB-II system was only designed to do engine monitoring. all the other aspects are created by the car manifacturer and different in every car since they dont have to follow a set of rules when creating these interfaces.
Pontiac Grand Am
building CarPC useing BookPC and Lilliput 7 inch TS.
djrkd is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
