11-24-2003, 10:44 AM
#1
does my car have odb ii
my car is a uk peugeot 306 1.4l model and was woundering if this was obd ii, its a 1996 model and i have searched for the connector but am unable to find it.
any help would be most greatful
Martyn ( www.essentialcruise.co.uk )
11-24-2003, 11:23 AM
#2
Registered User
Vehicle: 2000 BMW 323i
I know that all 1996 and newer cars are supposed to have OBD II, but Im not sure if that applies in europe. I also know that all of the ports have to be within 2 (i think) feet of the steering wheel, and labeled. Your manual should describe the location if you have one in the car.
There is some info here: http://www.obdii.com/connector.html but it looks like the rule was only for US.
11-24-2003, 05:11 PM
#3
Vehicle: Citroen Xsara 2,0 16V VTS
European cars don't have OBD-II until 2001, diesel engine ecu is not until 2000
Jan
11-24-2003, 05:13 PM
#4
Vehicle: 2003 Lancer OZ - RRM Turbo
obd2 port must be within 1 meter of the steering wheel.
11-24-2003, 08:45 PM
#5
Vehicle: 2004 Jetta GLS TDI (biodiesel)
And accessible without any tools.
11-25-2003, 04:26 AM
#6
_dopehead_ wrote
European cars don't have OBD-II until 2001, diesel engine ecu is not until 2000......
do'h wanted to do some stuff on it too.....
12-23-2003, 03:24 AM
#7
Vehicle: 2004 Nissan Frontier
Does anyone know if the 1988 Toyota Corolla FX has ODB-I or ODB-II? Where would I check?
12-23-2003, 03:31 AM
#8
Vehicle: Subaru SVX 1992 / Subaru SVX 1994 / Mitsubishi Galant 1999 / VW Passat 1998
88 Corolla will have ODB-I.
In US, only 96+ cars are required to have ODB II. Period. ODB III is in post deveploment stage and last time I heard, they are going to deploy that by 2006.
- Lwin M. Maung
If it's stuck, force it. If it breaks it needed replacing anyway
12-23-2003, 03:54 AM
#9
how can i tell if my mx6 has obd-i ???
12-23-2003, 11:32 AM
#10
1. What year is it?
2. Is it in the US?
3. If you look around the driver side (often times, it's hidden), do you see a connector that looks like this?:
- Lwin M. Maung
12-23-2003, 05:59 PM
#11
ok, well its an 89 mazda mx6 gt
its in australia
never seen a connector like that near the driver side
12-23-2003, 06:04 PM
#12
FLA
That would be a pre Obd2...I think its called a M.E.C.S on a Mazda
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
12-23-2003, 08:01 PM
#13
anyone have any idea what i need to do to extract infomation from it ???
12-23-2003, 08:07 PM
#14
FLA
Cant do much while the engine is running with mecs as far as I know. Let me rephrase. You can read what has happened as far as codes, or put into a test mode while running, but it is not like obd-2. Obd-2 is a real time type system, whereas you cant really monitor pids (paremeter identification), or look at real time info on earlier systems. I am going off of the mecs systems that are used on the Probe, a close cousin, with Ford diagnostics (NGS). Someone with a mecs scan tool may be able to provide more info, but from a "I know what works on a 89 probe" standpoint, it wont get you very far in looking into anything but trouble codes.
| Thread Tools |
| Display Modes |
Linear Mode
