The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 02-28-2008, 08:28 PM   #31
My Photos: (0)
I have 4 mazdas :
jsingh90210 is offline   Reply With Quote
Sponsored Links
Old 03-06-2008, 01:02 PM   #32
My Photos: (0)
ok...if i were to use the adapter from those mechanics handheld diagnostic tools (ie Carman Scan) thats for my make and model, can it be connected to the EL2M 327 OBDII scanner then to my cars diagnostic adapter in the engine bay.
Seeing that the diag tools can read data from the diag connector on the car would the adapter allow the obdii scanner to do the same????
Wagoneer is offline   Reply With Quote
Old 03-06-2008, 01:36 PM   #33
My Photos: (0)
I going through the same process looking for what is needed to display engin specs on a pc. and i saw cockie55 Had goten an answer from MR PTOR. What that particular answer was I don't have a clue? I need this help too? if you can find what mr ptor had said I'd like the thread to the answer. please I will also send the link to you if I can find it? Thanks jay
jayj200 is offline   Reply With Quote
Old 03-06-2008, 01:51 PM   #34
My Photos: (0)
http://www.mp3car.com/vbulletin/engi...interface.html
I have'nt had enough time to read in detail but from the brief preview it seems pretty interesting.
I hope it does the trick.
PS: tnx for the heads up on that info.
Old 06-25-2008, 10:35 PM   #35
My Photos: (0)
Angry OBD1 In A 1994 Dodge Intrepid
HEY,
I HAVE A 1994 DODGE INTREPID ES AND I WENT TO GET MY CAR CHECKED UP, BUT
THE MECANIC COULD NOT FIND THE OBD1 CONECTER PLUG. I NEED HELP!
I ONLY HAD IT FOR 6 MONTHS. I NEED TO KNOW WHERE THE OBD1 CONECTER IS
ON MY DODGE INTREPID. IF YOU KNOW COULD YOU PLEASE LET ME KNOW.
ALSO MY CAR SHUTS OFF ON ME EVERY ONCE AND A WHILE WHEN IM DRIVING. IF I GET IT CHECKED OUT WITH A COMPUTER DO YOU THINK IT WOULD HELP???
1994Dodge is offline   Reply With Quote
Old 06-25-2008, 11:10 PM   #36
Raw Wave
Tidder's CarPC Specs
Tidder's Avatar
Vehicle: 04 Pontiac Sunfire (The Racer is dead...)
My Photos: (0)
Sheesh man, no need to yell and/or thread jack. If the mechanic couldn't find it, maybe you should go to a different mechanic.
EDIT: Take it to a dodge/Chrysler dealer.
Tidder is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Larger VGA widescreen with touch options Yamato LCD/Display 3 04-05-2004 04:51 PM
Opus Solutions = Professional specsix Power Supplies 4 09-03-2003 08:27 PM
What are the ATX DC to DC power supply options? Squeezer Power Supplies 6 07-08-2002 04:25 PM
Extra power options? TheDingo Power Supplies 7 06-02-2001 12:19 AM
Visual options phorce General MP3Car Discussion 5 12-09-2000 01:36 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
