The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 12-12-2003, 05:24 PM   #1
My Photos: (0)
Twin VAG-COM cable consumes electicity?
I have Twin VAG-COM cable. Cable has a LED and this LED is "On" even, when I turn off the engine. I afraid, that it will drain some power from car's battery if I will leave it pluged in. Can I modify the cable, so it will not consume energy when car is off?
blaster is offline   Reply With Quote
Sponsored Links
Old 12-12-2003, 07:00 PM   #2
MeanGT's Avatar
Vehicle: 1993 Acura Vigor
My Photos: (0)
What is a VAG-COM cable??
My OLD Carputer: http://www.mp3car.com/vbulletin/showthread.php?t=17412
Currently, Don't have a carputer :( I sold my lincoln and bought a '93 Acura Vigor, plan on putting a carputer in it one of these days. You can see my vigor at: This Site
MeanGT is offline   Reply With Quote
Old 12-12-2003, 08:01 PM   #3
My Photos: (0)
OBDII software/hardware to use on Audi and VW. Check it here: http://www.ross-tech.com/vag-com/
Old 12-12-2003, 09:57 PM   #4
Vehicle: 99 Subaru Impreza Outback Sport (Black)
My Photos: (0)
The drain will be extremely miniscule since it is a LED, car alarms sometimes have multiple flashing LEDs and still have no problems.
kami333 is offline   Reply With Quote
Old 12-13-2003, 07:20 PM   #5
My Photos: (0)
yes, but LED is just an indicator. There is also some parts sitting inside and consuming power. Is there any way to test, how mutch power this thing consumes? I know, I can measure ampers, coming into the unit, but in order to do it, I will have to disasamble the console and cut the power wire.
Old 12-14-2003, 12:34 PM   #6
Stonewall78's Avatar
Vehicle: '99.5 VW Golf TDI
My Photos: (0)
I wouldn't worry about the current drain at all. If I remmeber correctly the drain for the whole unit is only like 50mA when all activated. Even then the LED only draws about 10mA so unless you leave it on for months at a time without starting the car you should be ok.
Stonewall78 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Custom length IDE cable (HD, CD/DVD, Floppy) jtk Classified Archive 13 03-23-2005 03:45 PM
A cable I found. masterful LCD/Display 5 08-17-2003 09:36 PM
Cat6 cable -> IDE Cable dan0myte General Hardware Discussion 8 08-31-2001 08:29 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
