The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Search this Thread Display Modes
Old 06-12-2007, 02:58 PM   #31
My Photos: (0)
http://www.walmart.com/catalog/produ...uct_id=5691045
I have an '03 Impala and this is what I used to put in my HU it is a jensen DVD player w/motorized 7' lcd the black box is the new chime box and all the wiring is pretty much plug and play w/ all the color codes.
$38.86 at your local Walmart
silverrage is offline   Reply With Quote
Sponsored Links
Old 06-13-2007, 07:06 PM   #32
My Photos: (0)
I contacted delphi and they sent over the pinout of the radio. See attached.
FlatSurfSucks is offline   Reply With Quote
Old 07-12-2007, 06:33 PM   #33
Vehicle: 2004 MAtrix XR
My Photos: (0)
Matrix 2004 Radio
This is all enlightening....but still not totally clear.
I bought this 2004 Matrix XR used. IT had a GM audio sytem with cd and cassette.
I took it out and had a car audio guy install a single width Pioneer. Reception was bad so I returned it and put in a Sony...... Still bad multipath reception.
The antenna is working because if I unscrew it from the roof I can hear distant station cut way down...
But is sounds like a poor antenna problem. I dont know if I blew it because it is a type2 databus????
I dont see anything else being effected accept that the rec eption is staticy even with strong city stations. As you drive around static comes in and out. I dont understand how you can put the original in the glove compartment and put a aftermarket radio in the slot at the same time???/ There must be another way.
ANy info would be appreciated.
edmellnik is offline   Reply With Quote
Old 07-13-2007, 09:36 AM   #34
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
Search in "audio electronic" section of matrixowners dot com or genvibe dot com forum regarding to antenna reception with aftermarket radio.
I'm sure you can find your answer cuz your searching skill is good .
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 07-14-2007, 02:13 PM   #35
My Photos: (0)
Matrix aftermarket
Thanks for the info.... I dont get a valid page when I try to go to
matrixowners.com so they must haved moved???
ed
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Cold hard drive fluid bearing data loss Michael Szilagyi General Hardware Discussion 2 12-13-2003 07:17 PM
IP Bus questions, Good chance to flame a n00b jigjew General Hardware Discussion 5 03-24-2003 10:02 AM
Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant? smoldyr General Hardware Discussion 1 11-14-2002 07:56 PM
Using a microprocessor to display GPS data on an LCD Zip-Lock GPS 15 10-21-2002 03:06 PM
CD data format specs? Jodoveepn Software & Software Development 5 11-02-2000 06:00 AM
Sponsored Links
Ad Management by RedTyger
