Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 06-18-2004, 10:48 PM   #16
Quote: Originally Posted by infinkc
heres a pic of the data that i can sample at the moment, its only been tested on an 98 audi a4 so far. Any other suggestions on what to add to the program besides the virtual dash?
That's actually very nice! Some cars have 2 02 sensors, however. Could you add a second option for that? Also - will there be options for N/A cars, Turboed Cars, Supercharged cars, and N02? (It'd be cool to have the computer throw the N02 switch.) Also - oil pressure and oil temperature. I know, I'm demanding, I'm sorry. Actually - I was planning on doing a project like this myself. What's that programmed in, VB?
Ravant is offline   Reply With Quote
Old 06-19-2004, 01:13 PM   #17
Banned
I originally started my own VB project on OBD, but stopped because I didn't have enough time.
If anyone needs any help in their projects, PM me. I can do basically ANYTHING in visual basics. I can also do any graphics related things you could want.
We need to have a good OBD solution that everyone can use and whoever needs help let me know.
As another member stated, right now the best solution is probably to use visualbasics OCX for OBD2 and OCX for Flash since that would make the graphics part very easy.
Nico3k is offline   Reply With Quote
Old 06-20-2004, 07:17 PM   #18
BoraXP's Avatar
how is the refresh time?
is it real time?
BoraXP is offline   Reply With Quote
Old 06-21-2004, 01:34 AM   #19
Magnezium's Avatar
Sorry. Been out of the state for a LONG time... I just got back... infinkc... It's not a module. Do you have flash? I can build the flash gui pretty fast. Just draw in Paint what you'd like it to look like (just a very general drawing for positioning and stuff) and I'll get to work on it.
Just your friendly neighborhood computer specialist.
2002 Pontiac Trans Am WS.6
Silver/Black
Looks like new... Wanna know why they call me "Crash"?
Magnezium is offline   Reply With Quote
Old 06-21-2004, 01:37 AM   #20
Jesus Freak
antimatter's Avatar
So i have been thinking about this for a while. Is there any progress on this. I don't have mu ODBII scanner module yet but intend to get it within the next 3 months and would like to creat some custom gauges. All the ones i have seen are very functional but not slick or flashy
antimatter is offline   Reply With Quote
Old 06-21-2004, 01:40 AM   #21
Magnezium's Avatar
I totally agree. I think with the right programming, and flash work, we can make changing the gui on the cluster easy and responsive. I was imagining using a access file to store the pictures in for the flash to pull up and load. Or we can use a ini or txt to store locations of pictures for flash to load. This way we can EASILY customize the display. Also, we can add coordiate points for where each pic is placed on the flash stage. So it would be a one time load up and customizing is made just that much more simple. I can do it... Anyone else in?
Mg
Silver/Black
Old 06-21-2004, 01:45 AM   #22
Magnezium's Avatar
Seriously, if you want it to look good, there needs to be a bit of real artwork that will go into it. I'm not very good at drawing, but I'm REALLY good at putting things together and making things work. If you can get the pics, I can put them together. Animated pics work too. Anything can be animated... In order to make one flash gauge, you need 2 seperate pictures: You need 1 gauge background with the numbers and all that, and then you need a needle. If you get these, then you need a cluster background. So you have your guages and cluster background. I picture all the guages having needles with a digital readout in the middle or under them. That would look slick.
Silver/Black
Old 06-22-2004, 07:31 PM   #23
Exo
Exo's Avatar
I too would love to have a slick looking dial set as all the software I have seen so far is functional but very dull! Thats the one thing which is putting me off getting the interface.
Try taking a look at (www.flashsim.com) they seem to have some nice dials etc, a few of which you can download for free.
I don't have ODBII yet so I couldn't do any testing but I do have a bit of VB experience.
Exo is offline   Reply With Quote
Old 06-22-2004, 08:09 PM   #24
You can also download Free Scan which has guages as well but works with OBDI PCMs.
http://www.andywhittaker.com/ecu/ecu_software.htm
Mray is offline   Reply With Quote
Old 06-23-2004, 11:11 PM   #25
99bravada's Avatar
I am a graphic artist and integrator and work with Flash and Flash Studio Pro almost daily... if you need any help with the graphics let me know...... has anyone tried doing this with Flash Studio Pro? It can read and write to the serial port and the ELM is serial interface... PM me if you need any help with the graphics... also, why not keep it all vector-based, or do a loadMovie to load in a .swf or .jpg if you would like to have an image.
Current:
2007 Black Diamond Toyota FJ Cruiser | Mac Mini (in dash) | Carnetix P1900 (in dash) | Apple Bluetooth Keyboard | Kicker KX350.4 amp | Pair Polk Audio 6.5"s in front
Coming soon:
12.1" touchscreen LCD (in dash) | US GlobalSat USB GPS receiver
99bravada is offline   Reply With Quote
Old 07-01-2004, 12:09 PM   #26
Have any of you tried using LabVIEW?
It is used for designing data aquisition systems mainly for industrial and academic research applications.
It has somewhat of a steep learning curve, but it is designed for data aquisition and display, which is what we need.
It wont make super shiny flashy dials like in flash, but they look verry nice and "industrial".
Also, it offers a lot more in terms of graphing and data manipulation, and can write to a spreadsheet, so you can save your data.
heres some examples. of what it can do:
http://www.ni.com/labview/express_demos.htm
http://zone.ni.com/devzone/conceptd....A?opendocument
Here is a good article about scanning ECUs with LabVIEW:
http://zone.ni.com/devzone/conceptd....B?opendocument
superart is offline   Reply With Quote
Old 07-01-2004, 12:55 PM   #27
Raw Wave
god_of_cpu's Avatar
Ow labview hurts my pocketbook. It starts at $1000.00 and thats without hardware.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 07-01-2004, 01:00 PM   #28
True, but some people get it for free throuigh their school or job.
I get mine from my school, which has a site licence.
Old 07-02-2004, 09:12 AM   #29
heypachuco's Avatar
True, but there are probably more of us that do not get it for free....
heypachuco is offline   Reply With Quote
Old 07-02-2004, 12:56 PM   #30
I know. I'm just saying, in the unlikely event that some people on this forum do have access to it, it is a wonderfull tool that is perfect for the job and shouldn't be overlooked.
For me, perdonally, its much more accessible than flash or flash studio pro, which were mentioned earlier.
I will try to make a preliminary mock-up tonight, and will try to post it.
Starting new thread for this. GPS software choice. unsavory GPS 2 01-06-2004 09:19 PM
GPS software waylonh Input Devices 3 11-25-2003 06:48 AM
DDO software Loftus Software & Software Development 10 04-01-2003 10:26 AM
List your software here! PoBoy Software & Software Development 2 08-12-2002 06:06 PM
My numpad controlled custom MP3Car software - need your opinions PorscheMP3 Software & Software Development 7 04-11-2002 10:30 AM
