Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 03-29-2004, 07:59 AM   #1
GTA
GTA's Avatar
Tuning through OBD?
Can cars be tuned through OBD?
Thanks.
Everybody has their own agenda.
GTA is offline   Reply With Quote
Old 03-29-2004, 08:11 AM   #2
Kalavera's Avatar
No, I'm afraid not. OBD reads information only, hence the 'Diagnostics'. Thought about that myself.
Thanks.
Current Cfg: AMD 2200+, Epox Mobo, 7" Lilliput TS, 320MB RAM, 40GB 2.5" HD, 200GB SATA, Slim Combo, ATI Radeon, SMC B/G Wireless w/ 5dB antenna, Bluetooth.
S/W: RoadRunner/MapMonkey/NetStumbler. Still working on a box and PSU!
Kalavera is offline   Reply With Quote
Old 03-29-2004, 12:43 PM   #3
SonicCobra03's Avatar
Incorrect. You can flash a cars computer through an ODB2 port. I have a 2003 cobra and there are two hand held tuners that plug in through the ODB2 port. When I had my car tuned it was flashed, so there's no sign of a chip. Check out SuperChips and Diablo has one out called the Predator.
If your talking about ODB1, then sorry, can't help you out there.
SonicCobra03 is offline   Reply With Quote
Old 03-29-2004, 12:49 PM   #4
Not every car supports this.
arkadiyp is offline   Reply With Quote
Old 03-29-2004, 06:38 PM   #5
Most cars (and trucks) do support flash via the diagnostic connector. There is a relatively new standard SAE protocol to do this as well.
Most OBD2 vehicles also support 2 way interfaces. From a "scan tool" you can turn on / off some devices and program in customer features like rolling locks / tilting side mirrors in reverse / etc.
BTW, when a dealership says their scan tool costs "thousands" vs. "hundreds" for consumer tools, it is not apples to apples comparison. Professional tools have lots more features and data support and hardware that meets OSHA and other standards - like Flash capability.
We wary of flashing with cheap scan tools (that probably will begin to show up in the next year or so) On many vehicles - if the flash is not done correctly or is stopped midstream - the controller (ECU) is throw away material as they don't have a boot sector resident.
DavidL is offline   Reply With Quote
Old 04-02-2004, 01:36 PM   #6
What is the name/id of the new SAE protocol?
When was it completed?
Is it mandatory for manufacturer's to implement it?
bambooracer is offline   Reply With Quote
Old 04-02-2004, 07:51 PM   #7
J2534 is the standard. It's been a while. It is mandatory.
Old 04-03-2004, 03:29 AM   #8
J2534 is standard as of 2004, it doesn't allow any non-OEM programming.J2534 allows the use of a "pass through" device(as SAE calls it), which is basically a translator(cheapest I have seen is $1700) that connects to the OBDII port and a windows 98+ computer.You can only reprogram factory approved software(downloadable from the OEMs through subscription services).All the software(upgrades and existing) are fully encrypted.
All OBDII ecus should be re-flashable(it is a requirement of OBDII compliance), but any 2-way communication with the ecu(other than basic diagnostic stuff) requires a factory security "code"(usually an expensive subscription).I also believe(not entirely sure) that the boot blocks are write protected, so no need to worry about trashing the ECU.
Eclipsed is offline   Reply With Quote
Old 04-03-2004, 11:23 AM   #9
Eclipsed,
J2534 hardware is just coming out now and will get cheaper.
Yes, it is today only for OEM software that has gone through emissions certification.
Yes, it is encrypted.
For most vehicles, no "code" for 2 way, just lots of hard work to translate, program and validate OEM protocols. The "code" is the OEM specific methodology for dialouging with the particular ECU. There are also on some vehicles intentional >12 volt step up to get into programming mode to avoid unintentional flash mode. And other safety related design issues.
Boot blocks are ECU specific. Many have no protection. Lots of ECUs are fried due to this issue. More recent ECUs do have boot sector and are safer to experiment with. So there is an issue of trashing MOST ECUs.
Old 01-17-2007, 04:12 AM   #10
hi all
i wonder if there is simulators or emulators to examine my new programe before i break my car down
plzz if any one know tell me ASAP
zondo is offline   Reply With Quote
Old 01-17-2007, 06:18 AM   #11
Query on OBD Analyzer
Hi,
Can someone tell me how do i analyze the OBD information recieved from ECU?
I am using CAN interface and i need to analyse the different data (DTC, Freeze frame ..) and display the recieved information using display interface.
So how do i analyse different types of data recieved from ECU ?
Ambika is offline   Reply With Quote
Old 01-17-2007, 10:26 AM   #12
http://en.wikipedia.org/wiki/On_Board_Diagnostics
Joel Konecny
Digimoto OBDII Diagnostics
digimotojoel is offline   Reply With Quote
Old 01-17-2007, 10:27 AM   #13
Also, in regards to this thread ~ for J2534 hardware (better pricing then what I saw in this thread), visit www.drewtech.com.
Joel Konecny
Old 01-17-2007, 11:35 AM   #14
i post here again, i think that no one reply as no one understand what i mean,
i need t know is there ECU emulators so i can try on (flashing memory) ??
Old 01-17-2007, 12:16 PM   #15
joeyoravec's Avatar
There's nothing that'll simulate the entire flash procedure available at any reasonable price. Many ECUs have a boot-block so you won't kill the ECU even if you have a bad reflash. Ford, Chrysler, newer GM's you're ok. Really it's the older VPW GM's that you have to worry most about killing.
joeyoravec is offline   Reply With Quote
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
Tuning chip firmware zvi General Hardware Discussion 1 03-16-2004 01:11 PM
? Potential damage to Carputer if dealer connects OBD device ? SAScooby Engine Management, OBD-II, Engine Diagnostics, etc. 2 03-08-2004 12:56 PM
best OBD tool skassama Engine Management, OBD-II, Engine Diagnostics, etc. 0 01-07-2004 10:13 AM
OBD USB or LPT1 Connectors? Ritalin Kid General Hardware Discussion 11 09-19-2003 10:01 PM
