The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Search this Thread Display Modes
Old 04-07-2004, 12:24 AM   #1
My Photos: (0)
GPS Speed Display
I'm working on a project to display speed of a vehicle using GPS data. I ran it on my PII 300Mhz computer, but seems like there's delay representing the data. Can someone in the forum try it out on their faster computer and get back to me with the result. I'll send you the files if you email me. Here's the picture of the display.
800Mhz PIII, DVD, IRman, ATI TV, Rage Pro 32MB, SB Live platinum, DC-DC ATX ps.
E-Mail: umsam@yahoo.com
My 4runner
umsam is offline   Reply With Quote
Sponsored Links
Old 04-07-2004, 12:31 AM   #2
cdm
Vehicle: import
My Photos: (0)
it's not a computer issue, it's a latency thing. it takes time for data to travel down from the orbiting satellites. it's normal.
cdm is offline   Reply With Quote
Old 04-07-2004, 12:40 AM   #3
My Photos: (0)
Thanks, but I know about that issue. When I run it on my PII computer, I can't even move the mouse at real time. When I run it on my desktop, it runs much faster, but I can't move the desktop to test it out. I know the speed won't be totally real time, but I want it to get it close as possible.
My 4runner
Old 04-07-2004, 08:58 AM   #4
My Photos: (0)
Umm GPS NMEA message come once a second that means your speed will only get updated ONCE A SECOND no matter how fast your computer is. The only way around this might be to use third-party binary protocols offered by Garmin and other GPS's but they will not be compatabile with all GPS's. GPS is just not a good way to get any accurate vehicle speed- OBD-II would be the ideal way to do that.
siberia37 is offline   Reply With Quote
Old 04-07-2004, 03:00 PM   #5
kiltjim's Avatar
Vehicle: 2000 Subaru Impreza Outback Sport
My Photos: (0)
I haven't tested it out, but I can see one very big problem right off the bat...
It only goes to 150. Just my 2 cents though. Nice job otherwise.
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 04-07-2004, 03:31 PM   #6
Vehicle: 2005 PT Cruiser
My Photos: (0)
where are you driving that you need above 150 ?
Scorp
Scorpnstail is offline   Reply With Quote
Old 04-07-2004, 04:13 PM   #7
ukchris's Avatar
Vehicle: Porsche Boxster S
My Photos: (0)
Have a read through this thread too http://www.mp3car.com/vbulletin/show...6&page=2&pp=15 unfortunately I lost the source code to a disk crash but I may start over when I get my laptop rebuilt. I think the link to Frodo's site has the first version, I have a compiled exe of the second version if anyone wants to try it.
My aim was to display speed, heading etc and then add tracking to this so that the app could run and track where it went and how fast such that you could automatically log data when someone borrows your car etc.
Chris.
ukchris is offline   Reply With Quote
Old 04-07-2004, 09:40 PM   #8
ukchris's Avatar
My Photos: (0)
My prototype is available here http://www.manwhoring.com/mp3car/ukchris/
Old 04-07-2004, 10:23 PM   #9
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
Check your CPU usage. You should really only be using 0% about 95% of the time. If not, either the serial reader is polling instead of waiting on events, or you're drawing more than once per second. Make sure you're not getting hundreds of reads per second on the serial port first. That would really slow things down.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 04-07-2004, 10:40 PM   #10
Raw Wave
jjh221's CarPC Specs
jjh221's Avatar
Vehicle: 1998/Ford/Explorer
My Photos: (2)
i like it, 2 cent: colors on most used speeds. like 65 here in states and larger numbers. For me it would be more easy to view the color change than the numbers.
jjh221 is offline   Reply With Quote
Sponsored Links
Old 04-08-2004, 06:01 AM   #11
Vehicle: 1980 Holden Commodore VC
My Photos: (0)
Hi,
I'm from australia and down here we use KM/H would it be possible to change this? By the way i'll email you about testing the program out.
CarPC: Currently in progress...
aphesis is offline   Reply With Quote
Old 04-16-2004, 01:55 AM   #12
Registered User
gork's Avatar
Vehicle: BMW E46 M3
My Photos: (1)
siberia37: actually, binary protocols will not help with the update frequency. Almost all gps's update their position information at 1Hz, and thus their average speed. I looked into GPS's that do it faster and found some 5Hz update models (Garmin GPS16A), but they are all very expensive ($300+) due to this fact. Also, the speed returned by the GPS will be the average speed over the last second (or 1/5 second on a 5Hz gps) immediately when it is sent out the serial port.
You could couple the GPS data with input from an accelerometer to determine speed changes between GPS updates without sacrificing accuracy too much. The math for this dead reckoning gets a little complicated, but it's still very do-able and the accuracy is pretty good, too! www.phidgets.com sells a pretty inexpensive accelerometer.
MY CAR IS FOR SALE!
See My Project Page for Details - 2003 BMW E46 ///M3
Custom Dash Monitor Housing - OEM Fitment
Custom Overhead DVD-ROM Housing in Headliner
BMW I-Bus Integration
My homepage with many other fun projects!
gork is offline   Reply With Quote
Old 04-23-2004, 03:33 AM   #13
ob1
ob1's Avatar
My Photos: (0)
Or you could do some predictive interpolation of just the GPS output i.e. if the last GPS speed read was "v" and the speed before that was "u" and the present moment is "x" milliseconds after "v", the current speed is approximated by:
( (v-u) * x/1000 ) + v
assuming your acceleration rate does not change much over the 1 second interval.
ob1 is offline   Reply With Quote
Old 04-23-2004, 03:58 AM   #14
craigyb's Avatar
Vehicle: 2001/Toyota/Hiace
My Photos: (0)
Umsam
Where can we get the code to test it. I will give it a go this weekend.
Audi S8 supercar
Modded Xbox 400GB HD
Rear 7" screen & navplus
Toyota Hiace Van
Shuttle PIII 866 256Mb 10GB OPUS powered
MediaCar & Mappoint 2004
Custom fit 7" TFT VGA TSK
craigyb is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Anyone Help Test a GPS App? ukchris Software & Software Development 42 04-08-2004 03:37 PM
GPS DATA on HD44780 char Display ?? felix99 GPS 8 01-10-2003 04:56 PM
Using a microprocessor to display GPS data on an LCD Zip-Lock GPS 15 10-21-2002 03:06 PM
Screensaver to display gps data? larstore Software & Software Development 0 06-13-2002 06:19 AM
good display for GPS? Necare General Hardware Discussion 0 08-29-1999 02:24 AM
Sponsored Links
Ad Management by RedTyger
