Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 06-18-2004, 09:04 AM   #31
tell me about it ! I got a quote from a company for a 1 off PCB - it was so expensive to set everything up for just one they wanted £80 for it !!!
So i ended up doing it myself, i don't have a UV unit so did the old laser toner/clothes iron trick and then going over with etch resist pen for a reasonably neat PCB
James
www.digital-car.co.uk - The UK CarPC Forum
Jamez_Warner is offline   Reply With Quote
Old 06-18-2004, 10:21 AM   #32
Raw Wave
You meant this stuff :
http://www.maplin.co.uk/products/mod...464&Products=1
Havent really tried it but I heard it doesnt work too well when theres many fine tracks on the artwork.
UV light is probably one of the most useful stuff when playing with PCB. Yes is always expensive for a 1 off PCB. The cost should only be a few pounds if you were to order 1,000s.
Ricky327 is offline   Reply With Quote
Old 06-18-2004, 10:49 AM   #33
Clover
Grayscale's Avatar
Soooo Jamez? We don't care that it's labor itensive, we just want a PCB!!! Lol, seriously, how much is that in USD?
CarPC install is starting to come along again...
Grayscale is offline   Reply With Quote
Old 06-18-2004, 11:20 AM   #34
Raw Wave
If you want PCB and components based on the simple circuit then go here :
http://www.skpang.co.uk/obdii_hardware.htm
The cables are expensive though.
£ to $ rates is here :
http://www.xe.com/
Old 06-18-2004, 11:29 AM   #35
Raw Wave
http://www.skpang.co.uk/elm323.htm#elm323_kit
Old 06-23-2004, 11:44 PM   #36
doing pcb's with toner transfer paper is not that hard, i've done boards in under 15 minutes
greenwire is offline   Reply With Quote
Old 05-23-2005, 02:59 PM   #37
Hi PIMPJ!!!
Could you send me the source code in VB you had?
Thanks in advance
email:esteban.trinidad@tigo.nrt.py
Esteban
esteban2 is offline   Reply With Quote
