Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 05-15-2004, 01:32 AM   #1
Fox_Mulder's Avatar
Arrow OBD In Australia?
I have looked under my steering column and i have found a black connecter in the same shape with the following pinouts:
(Yellow indicates there is a pin there)
Now all I have to know what protocol it uses. For ISO the connector must have pins 4, 5, 7, and 16. Pin 15 may or may not be present. Is this correct?
If it makes any difference the car is an Australian 2001 Toyota Avalon Vxi.
Thanks,
Fox Mulder
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353
Fox_Mulder is offline   Reply With Quote
Advertisement Sponsored links
Old 05-21-2004, 02:44 AM   #2
stimps's Avatar
yeah help with this would be great, I have a new FORD XR6Turbo and would like to do the same. Does my car have it?
stimps is offline   Reply With Quote
Old 05-21-2004, 06:28 AM   #3
ob1
ob1's Avatar
Common dood.....google 2nd page:
http://www.emergent.com.au/~cmoran/my_xr6.html
this guy seems to think it has OBD.
ob1 is offline   Reply With Quote
Old 05-24-2004, 02:44 AM   #4
Most certainly is OBDII - speaking with a Ford dealership those palm pilot/WinCE based OBDII plug in units do work. As to the pin outs? nfi sorry.
parawolf is offline   Reply With Quote
Old 05-24-2004, 06:15 AM   #5
stimps's Avatar
ok cool, ill have to search around and see if anyone has the pinouts and interface chip working, and actually doing something good on the PC, that someone has written code for (guess its early days yet)
Old 06-20-2004, 01:53 AM   #6
The pinouts should be the same as the US Mustang - however the EEC version is different which means some of the factory specific fault codes could be different.
Old 06-20-2004, 06:02 AM   #7
djmickyg's Avatar
only american cars have to have obd.. it is ocming to australia soon
most new toyotas have the plug under the coloum but the pin outs will be all mixed up to what there ment to be..
a few holdens will have it as there exported to america i.e the manaro (pontiac gto)
djmickyg is offline   Reply With Quote
Old 06-22-2004, 08:22 AM   #8
My 2003 Mitsubishi TJII Magna was sold in US as the Mitsubishi Diamante... so im hoping its got OBD too... anyone know for sure if its active?
WSDsmurf
WSDsmurf is offline   Reply With Quote
Old 06-23-2004, 03:08 PM   #9
muldrick's Avatar
WSDsmurf
All '96 & up U.S. passenger vehicles have this OBDII, it is a fed.gov. standard.
I use my Palm to get vehicle info from this connector.
when using generic software (like I do) you only get OBDII info. (like readable trouble codes) Some DTC's my say "Manufacturer Specific" which'll only show the DTC #. Others DTC's that are under the Fed. guidelines will state what the Trouble code means, like "O2 Sensor out of range".
You also get basic info. like RPM, Coolant Temp, MAF Meter, Throttle Position, etc.
You would have to buy a cable and some kind of translator box.The software I use (for my Palm) also has a desktop version but I haven't tried it.
I got this at: http://www.ghg.net/dharrison/
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
Calculate HP base on OBD II data? god_of_cpu Engine Management, OBD-II, Engine Diagnostics, etc. 7 04-16-2004 01:43 AM
? Potential damage to Carputer if dealer connects OBD device ? SAScooby Engine Management, OBD-II, Engine Diagnostics, etc. 2 03-08-2004 12:56 PM
OBD USB or LPT1 Connectors? Ritalin Kid General Hardware Discussion 11 09-19-2003 10:01 PM
