The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 05-23-2004, 10:43 PM   #1
Vehicle: 2004 GMC Yukon XL
My Photos: (0)
ODB II and GM DIC
Anyone know if you can tap into the GM DIC (Driver Information Center)? Is that part of ODB II?
DIC provides users with this and more:
fuel used
MPG/KPG
trip odometers
oil change schedules
HOBBS meter (engine hours)
Thanks...
cw95403 is offline   Reply With Quote
Sponsored Links
Old 05-23-2004, 11:28 PM   #2
My Photos: (0)
fuel used
MPG/KPG
trip odometers
Thanks...
None of those are standard ODB-II PID (item you can read from the interface) AFAIK. You may be able to get them from a manufacturer specific PID though. Good luck finding info though.
siberia37 is offline   Reply With Quote
Old 01-11-2006, 03:33 PM   #3
My Photos: (0)
any luck with interpreting the signal for the DIC?
anyone else for that matter?
specific vehicle is a '06 G6 with the DIC in the radio. i know they produce a dash kit that keeps the functionality (simple LCD display), but i'd love to be able to incorporate the data into a self designed program i want to make...
Vita is offline   Reply With Quote
Old 01-24-2006, 04:47 PM   #4
My Photos: (0)
anyone have any ideas? i know there is an aftermarket headunit mounting kit that retains DIC info. what would one do to interpret the signals? (given i can figure out what wires are associated wwith the DIC)
is grabbing those signals and sending to the CPU for interpretations something more for the hacking section?
Old 02-28-2006, 12:49 PM   #5
My Photos: (0)
the chip is on the back of the cluster, Its actualy part of the dash cluster and not directly dependant on the cpu. Depending on the manufacturer I beleve yours has a motorola 68MC9S1 Pins 49 , 7, 23 are your data, rts and rtc yes you would need to hack the dash, I can get you the specs , pinout if you give me the make and model of the car.
Heroshima is offline   Reply With Quote
Old 03-07-2006, 09:33 PM   #6
My Photos: (0)
I just bought an elmscan5 and i am sniffing the classII data trying to figure out the protocol. This is among the things on my list. I will post my findings.
Rickertsen2 is offline   Reply With Quote
Old 03-08-2006, 07:28 PM   #7
My Photos: (0)
on my 04 impala, the DIC seems to have a physical address of 61. I made a list of all the modules with heartbeat signals. I then unplugged my DIC and 61 stopped beating.
Old 03-20-2006, 02:58 PM   #8
My Photos: (0)
Thumbs up
The DIC is available on some Vehicles and can be updated. I know that you can update it on the Chevy Malibu and the G6. On these two vehicles the entire message is packed within two messages. Because CAN limits data bytes to 8 per messages a DIC with 16 character display requires two messages to fill the DIC. The lettering is stardard ascii and will most likely only be available on the low speed single wire can network NOT the high speed dual wire network. You can simulate this messages by sending the a messages with the appropriate arbitartion ID on CAN. The message however will be over written as soon as the BCM (or whatever module normally sends the DIC messages) sends another message. Fortunately this is not normally a periodic message but rather a event driven messages. This means that when the door opens a message is sent an another one is not send until the door is closed and so on. This is probably one of the easiest message to reverse engineer as it is event driven and filled with ascii databytes that a lot of software can view in that form. There is an online demo of this exact feature at "http://www.intrepidsupport.com/present/hijackdemo/" But the software here is ment for professional engineers and it's price is set as such, so It may not be what you are looking for (or maybe you are an engineer and it is), but they give a good idea of what you need to do to reverse engineer the "Message Center" or DIC.
chewwtoy is offline   Reply With Quote
Old 03-20-2006, 09:02 PM   #9
My Photos: (0)
There is also the non text-based version of the DIC in some cars. I noticed that in my impala, the radio display also uses ascii commands several messages long. Everything shown in that video can just as easily be done with a simple terminal program. It is cool none the less.
Old 05-02-2007, 05:59 PM   #10
My Photos: (0)
Did anyone ever have any luck with tapping into the GM DIC?
drumminmandan is offline   Reply With Quote
Sponsored Links
Old 05-13-2007, 06:30 PM   #11
xcalibur's Avatar
Vehicle: 1992/Pontiac/Grand Prix GTP
My Photos: (0)
i wired a DIC into my 1999 grand prix gt and the only info that those things pull from the OBD is the fuel pump informations which it uses in sync with you speed and rpms, to calculate everything it needs
P4 1.8GHZ, Ati 9600se 128mb, WD 120gb hd, liliput 8" touchscreen, m2-atx
xcalibur is offline   Reply With Quote
Old 05-14-2007, 02:17 AM   #12
My Photos: (2)
Here are some codes from OBDPROS forum.... I would love to code a centrafuse plugin for this....
Engine oil life remaining
E9 4A 00 14
Response is 14 XX
XX converted to decimal divided by 2.55 is the percent oil life remaining
Unlock car doors
Force the interface into VPW mode by issuing
>ATSP2
Now set headers to address the correct module
>ATSH 8A C5 A1
Now To unlock doors Type in
>A1 26
To Lock Doors type in
>A0 26.
==Change Interior light brightness:==
A8 DF 40 91 80 1E sender: manu spec recv: BCM
XX XX XX YY ZZ XX
YY - command?
ZZ - brightness
==set High beam dash light:==
off - 8A EA 40 20 91 00 9B
on - 8A EA 40 A0 91 00 5B
== Tachometer ==
88 1B 10 10 XX 0D 11
xx = rpm * 100
== door adjar Indicator==
on - 8A EA 40 A0 A5 00 B7
off - 8A EA 40 20 A5 00 77
== trunk open Indicator==
on - AA EB 60 A0 A6 00 6B
off - AA EB 60 20 A6 00 AB
== brake light ==
8A EA 40 20 98 00 8D
==Make radio beep:==
68 96 XX 91 YY ZZ
ZZ - number of times to beep
YY - style or duration of beep
==Kill everything in the interior of the car==
28 FF 40 06 03 00 0B 0B
==send out by radio upon button presses - chechsum will be different==
6A A4 80 21 B2 01 58 - tune fwd
6A A4 80 21 B2 FF 81 - tune rev
6A A4 80 99 B2 01 BC - seek up. alternates btw this and the below
6A A4 80 99 B2 00 A1
6A A4 80 99 B2 02 9B - seek down alternates btw this and the below?
2003 Black Impala
Dwaine is offline   Reply With Quote
Old 11-03-2007, 12:41 PM   #13
lor109's CarPC Specs
lor109's Avatar
My Photos: (11)
Install in my 05' Malibu
I am taking the leap to remove my Factory Headunit and replace it with a touchscreen. I would really like to keep the DIC usable. Options are: Relocationg, Figuring out how to control Via Carpc, Metra adaptor kit. I am building a bezel for my 7" Touchscreen to fit directly into the dash space for an OEM look, so Single din + Metra kit is not really an option. Relocating may be the only solution, but it seems like a wiring nightmare. When I saw this thread I got excited thinking maybe someone had figured a way out to use the pc to operate basic functions of the DIC.
Has anyone gotten anywhere with this? I'm not nearly skilled enough to program an interface, or I would be all over this.
Thanks in advance for any input.
Nathaniel
lor109 is offline   Reply With Quote
Old 11-12-2007, 02:35 PM   #14
lor109's Avatar
My Photos: (11)
Bump
Old 04-08-2008, 01:59 PM   #15
lor109's Avatar
My Photos: (11)
Anyone ever figure this out?
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
