The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 06-18-2004, 08:01 PM   #1
Phat Boy
Pudge's Avatar
Vehicle: 1998 Hyundai Tiburon FX
My Photos: (0)
Scantool or OBDdiagnostics
http://www.scantool.net
or
http://www.obddiagnostics.com/order.html
I've heard that ELM is somewhat limited, although It's only been hinted at. The OBD Diagnostics one looks cool because it appears that the one unit supports all OBD interfaces (ISO, PWM, VPW). With OBD Diagnostics, I could use that on all of my cars, whereas with the ELM ones I'd have to buy 2 (Domestic/Import). What are your suggestions? Also what software is best, I was thinking about using OBD Diagnostics software.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
Pudge is offline   Reply With Quote
Sponsored Links
Old 06-18-2004, 08:39 PM   #2
migel628's CarPC Specs
migel628's Avatar
Vehicle: 2002 Nissan Sentra SE-R Spec V
My Photos: (0)
I can't speak on Scantool, but I did get the completed BR-3 & it's pretty cool.. I haven't done too much w/ it though. The software from the site is also pretty cool, even if it does look a little outdated.
"I'm a dick!"
"I must seek knowledge and it's bastard son truth" - The State
migel628 is offline   Reply With Quote
Old 06-18-2004, 09:11 PM   #3
Phat Boy
Pudge's Avatar
My Photos: (0)
Can you do diagnostics as well as stats, like I know the one at the local Checkers, you just plug in and it tells you what's wrong.
2 Kicker Comp 10"
Check it out?!
Old 06-21-2004, 08:12 AM   #4
My Photos: (0)
I also have the BR-3.
The software can give you the basic stats in "graphic" or text mode, i.e. speed RPM temperatures. There's an O2 sensor page, which is beyond my comprehension, and a trouble code page that reads the Check engine light and lets you reset it or whatnot.
Sensor is offline   Reply With Quote
Old 06-21-2004, 08:13 AM   #5
My Photos: (0)
http://www.obddiagnostics.com/ScrnShot/Winscreen.html
Has screenshots of all windows in Windows version. Which reminds me: as far as I can tell, the data coming out of the BR-3 tool is not to the 'standard' that OBD's accept, so you can't switch softwares. I could be wrong, though, as I haven't tried.
Old 06-21-2004, 11:23 AM   #6
Phat Boy
Pudge's Avatar
My Photos: (0)
"I haven't tried" being that the software it came with is acceptable? It doesn't need to be too fancy, I simulated it and it looks pretty good.
2 Kicker Comp 10"
Check it out?!
Old 06-21-2004, 01:54 PM   #7
My Photos: (0)
I meant that I haven't tried using any software other than that which comes from obddiagnostics.com, but I am under the imrpession that other software would not work.
Old 06-21-2004, 05:47 PM   #8
Phat Boy
Pudge's Avatar
My Photos: (0)
I know, but you found the software it came with was good for you?
2 Kicker Comp 10"
Check it out?!
Old 06-23-2004, 03:14 PM   #9
muldrick's CarPC Specs
muldrick's Avatar
Vehicle: 2004 Hyundai Accent
My Photos: (2)
I use this: http://www.ghg.net/dharrison/ with my Palm.
I haven't tried the windows version (I'm fixing to)
With this software you can also check DTC's and reset the chk engine light.
Most software I've found is pretty basic and not any better than this.
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 06-26-2004, 03:53 PM   #10
asci01's Avatar
Vehicle: Lexus GS300
My Photos: (0)
Is there any ODB-II that can tell you real time fuel efficiency in miles/gallons?
asci01 is offline   Reply With Quote
Sponsored Links
Old 06-26-2004, 09:58 PM   #11
wi77iam's Avatar
Vehicle: 2004 Subaru WRX STi
My Photos: (0)
This one can compute real-time MPG, but your car's ECU has to be able to supply the right codes. Not all do.
wi77iam is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
scantool vs autotap shakes Engine Management, OBD-II, Engine Diagnostics, etc. 8 11-26-2003 10:00 PM
Sponsored Links
Ad Management by RedTyger
