Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 06-30-2004, 05:11 PM   #1
OBD on motorcycles
I did some searching, but couldnt find any info on OBD systems for motorcycles.
does anyone have some links or info on motorcycle OBD systems or standards?
Thanks.
superart is offline   Reply With Quote
Old 06-30-2004, 05:14 PM   #2
Raw Wave
jjh221's Avatar
look up power commanders.
On newer bikes
jjh221 is offline   Reply With Quote
Old 06-30-2004, 07:38 PM   #3
Thanks.
I looked into the power commander, and from what I understand, it is basicly a controler for timings and fuel injection. If that is all it does, I woul rather go with the yoshimura EMS box, since they have optimised maps for yoshimura exausts and can switch between 3 different maps while runing, as well as different maps for individual gears.
What I am really looking for is a sysyem that can read real time telemetry from the bike, like engine RPM, throttle %, vareous temps, o2 levels, etc...., and feed tha to a computer I plan on encorporating somewhere onboard. Preferably, I would also like to be able to display this real time as well. Sort of like this:
http://www.obd-2.com/dashg.htm
any suggestions?
Thank you.
Old 12-15-2006, 05:20 AM   #4
Check this out, may be what you are after?
http://www.probike.co.uk/it080002.htm
thewasp600 is offline   Reply With Quote
Old 12-15-2006, 07:26 AM   #5
_
honnestly, I don't believe it would be stable enough yet to trust it on a bike, especially if the bike were to be ridden on the street. Track is something else entirely.
There's no standard for bikes like there is for cars. Your best bet is to go to a standalone system like what you've linked.
I've never seen the ProBike thing. Will be doing research on it now...would be nice to have something like that for our bikes.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is online now   Reply With Quote
Old 12-15-2006, 07:41 AM   #6
Thanks.
What Bike do you have? I have heard that Harley's use J1850 VPW. I think there is a poster on here who might know more, I do not have his name but I will try searching through the other posts and report back
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 12-15-2006, 08:28 AM   #7
2D Datarecording - a couple of very bright German engineers who love to race motorcycles created their own data recording system designed for race use.
http://www.2d-kit-system.com/English/home.html
Their system uses a connection to the CAN-BUS system on most newer bikes and cars, which is what your OBD connector taps into. Unfortunately manufacturers limit what you can see with OBD, so this bypasses this limitation. Once in the CAN-BUS, they can read almost every signal available, and add external inputs with add-ons like GPS, suspension travel, temp sensors, etc.
I worked with them at a previous job to do data logging on new cars so that we could develop and test exhaust system components to real-world test track motion. Good stuff.
recneps is offline   Reply With Quote
Old 01-31-2007, 07:56 PM   #8
I got a Power commander 2 USB for my raptor 700r, and hook it to my laptop. i get quite a bit of info, but not as much as from an obd. I can also make changes with my laptop to the bike through the PC2 USB. Like fuel/air, top speed, rev limit, adjust for aftermarket acc., and throttle postion/fueling, defueling , and more. they make'em for alota bikes, just get the usb version.
southtarnation is offline   Reply With Quote
Old 06-06-2007, 04:07 PM   #9
Here's a bike video data logger
http://www.pashnit.com/forum/showthread.php?t=3098
http://media.putfile.com/DataAcq
http://media.putfile.com/track334/original
sweetie is offline   Reply With Quote
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
Comments on BR3 OBD Reader sontakke Engine Management, OBD-II, Engine Diagnostics, etc. 4 05-13-2004 07:57 AM
Calculate HP base on OBD II data? god_of_cpu Engine Management, OBD-II, Engine Diagnostics, etc. 7 04-16-2004 01:43 AM
? Potential damage to Carputer if dealer connects OBD device ? SAScooby Engine Management, OBD-II, Engine Diagnostics, etc. 2 03-08-2004 12:56 PM
OBD USB or LPT1 Connectors? Ritalin Kid General Hardware Discussion 11 09-19-2003 10:01 PM
