Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 07-10-2004, 12:31 AM   #1
asci01's Avatar
asci01 is on a distinguished road
Gas mileage
Is there an ODB-II/software combo that can give you real time gas mileage?
If not, is it a hardware limitation?
asci01 is offline   Reply With Quote
Old 07-10-2004, 01:17 AM   #2
owenjh's Avatar
owenjh is on a distinguished road
You could log data and then tell your gas mileage. Im not sure if OBD-II can get the current milage of the car or not, but it can get the fuel trim levels. Im guessing you would have to homebrew your software to get it to do this, I don't know of any software that does this, but some one else might. I was interested in calculating my gas mileage properly, If i ever get an obd-II interface I will make an app for it.
CarComputer Status: New Car & Broken (Motherboard Fried)
Owen JH | My Linux Blog | The Tech Fellows
owenjh is offline   Reply With Quote
Old 07-10-2004, 01:49 AM   #3
asci01's Avatar
Great. At least there is no hardware limitation.
P.S. can you give me more information about what the "fuel trim level" is
Old 07-11-2004, 09:32 PM   #4
wi77iam's Avatar
wi77iam
The limitation is not hardware or software - it all depends on whether the car's ECU supplies the right codes to compute it. Some manufacturers provide codes for this and some don't.
wi77iam is offline   Reply With Quote
Old 07-27-2004, 04:16 PM   #5
owenjh's Avatar
Not really that good at OBD-II myself, but I believe (some one correct me if im wrong) that fuel trim level is the amount of fuel left in the vehicle.. So your gauge that tells you how much fuel is in your car is your fuel trim level.
Old 08-03-2004, 06:16 PM   #6
crash893 is on a distinguished road
incorrect
fuel trim level ( there are two short term and long term)
basicly fuel to air mixture
rich or lean
in theory you could add up the fuel trim level to see how much gas your useing but its hard and odbII doesnt give you enogh granularity to see it properly
crash893 is offline   Reply With Quote
Go get gas now!! PoBoy Off Topic 25 08-31-2007 11:58 PM
Gas Calculator siduri99 MediaCar 55 07-05-2006 05:33 PM
How to make a hydrogen car!! RaZor Off Topic 39 05-24-2005 11:54 PM
Anyone knows how can I convert the mileage to digital values? e1fnd Software & Software Development 22 06-18-2003 12:35 PM
Fuel tank burst of gas...problem??? PoBoy Off Topic 7 07-02-2002 10:19 AM
