Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 07-27-2004, 10:27 AM   #1
obd windows go down
hello i have a 99 acura and i was wondering if i could use the odb to control my windows (glass not os), what i was thinking if i push the remote to unlock my doors 5 times the windows would go down (if i push it once it un locks the driver door, if i push it twice it unlockes the pass. door,) and push it to lock 5 times it will roll up the windows. i know you can get an After market alarm with window mod but i want to keepo my FOB, so will this work?
thanks
pyr0000 is offline   Reply With Quote
Old 07-27-2004, 06:11 PM   #2
kiltjim's Avatar
I am new to all this OBDII stuff, but I am almost absolutely sure that your ECU will provide that type of information. It is really meant to report data from the engine, exhaust, etc. I don't believe its going to have the position data from the windows.
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 07-28-2004, 10:14 PM   #3
Phat Boy
Pudge's Avatar
Try a search for "Relay Boards" on google for the hardware, then here for interfacing it.
Edit:: here's a good starting point http://www.quasarelectronics.com/3074.htm
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
Pudge is offline   Reply With Quote
Old 07-31-2004, 05:56 PM   #4
The Body control module is usually the one that will control windows (for those equipped with this control type). It would not be available via the generic OBD2 mode. Only in enhanced with connection to the Body control module (not very common for non OEM scan tools).
DavidL is offline   Reply With Quote
Windows Freeze When Crank, Crank again windows unfreeze antimatter Power Supplies 37 07-27-2004 12:40 AM
Windows ME and MediaCar dug1967 MediaCar 15 04-15-2004 01:30 PM
Booting another application as windows shell psyclobe Software & Software Development 13 02-10-2004 10:27 PM
A few observations in OS and why I'm now using Windows 2003... Mastiff Software & Software Development 12 01-21-2004 09:11 AM
new windows shell & 'shell=' for win2K magnetik Software & Software Development 2 04-16-2002 08:47 PM
