The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 07-31-2004, 07:34 AM   #1
moonshinemadnes's Avatar
Vehicle: 1998 Peugeot 306
My Photos: (0)
Turbo readouts from OBD?
Is it possible to get OBD-II Readouts of turbo information, if the turbo was standard on that particular car? When i say readouts im thinking Turbine RPM, Boost Pressure, Intake Temp, Intake Amount and Power graphs?
This would save me buying a turbo timer for a start because i would be able to see when the speed had dropped enough to safely stop the engine. Anyone know?
]Controlling You Through A Chip In Your Butt Since 1999 [*~Mikee~*][ Audiophilia -When your subwoofer makes your cd player skip]
moonshinemadnes is offline   Reply With Quote
Sponsored Links
Old 07-31-2004, 08:30 AM   #2
My Photos: (0)
No car monitors turbine rpm. You'd have to have something connected to the shaft of the turbine housing to monitor this. Also a turbo time has absolutely nothing to do with the turbine still spinning. You use a turbo timer so the car can sit at idle for a while to allow the oil in the turbo to cool down. If you constantly are turning the car off after you beat on it with hot oil circulating in the turbo you can cook the bearings inside which will destroy the turbo. And a turbo will never stop spinning until you turn the car off anyways. They are driven by exhaust gas so unless the exhaust gas stops they will spin.
As far as those readouts obd II can tell you intake temp normally, and if from the O2 reading you can figure out your intake amount in a way. By reading the output voltage from the O2 you can if you are getting enough air/fuel mixture or if it is running lean. I'm a turbo nut (all my cars have had one) so if you ever have any questions about them feel free to ask
Sid3ways S13 is offline   Reply With Quote
Old 07-31-2004, 04:53 PM   #3
My Photos: (0)
Thanks, i always thought the reason you had to leta turbo idle was to let it slow down while still lubricated...learn something new everyday
Thanks for the info, great help
Sponsored Links
vB code is On
Trackbacks are Off
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
Calculate HP base on OBD II data? god_of_cpu Engine Management, OBD-II, Engine Diagnostics, etc. 7 04-16-2004 01:43 AM
? Potential damage to Carputer if dealer connects OBD device ? SAScooby Engine Management, OBD-II, Engine Diagnostics, etc. 2 03-08-2004 12:56 PM
OBD USB or LPT1 Connectors? Ritalin Kid General Hardware Discussion 11 09-19-2003 10:01 PM
Status of my RX-7 turbo conversion Aaron Cake Off Topic 9 01-23-2002 02:17 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
