Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Notices
Old 08-08-2004, 02:13 AM   #1
Zoltan's Avatar
OBD Diagnostics connected all the time?
Hi Everyone,
After searching here a long time, I ordered the OBD Diagnostics BR-3, and I got the following email response. I'm very happy that Bev is being very forthcoming about the product and doesn't want to ship me something I'll be dissapointed with, but I'm curious if you guys think she's being overly conservative.
I suspect that many of you use the device exactly as I have planned, and I was wondering if any of you have experienced what Bev describes below.
Thanks,
Rob
Hi Robert, What we have is mostly designed as a simple diagnostic tool, it
doesn't have a watchdog timer or any sort of automatic operations, so it may
not be suitable for what you need. For example, it may loose connection when
cranking an engine, especially if the battery is low, weak, or weather very
cold, and the only way to reset it is to unplug it and start over.
I'll put your order on hold until I hear from you and there will be no problem
to cancel it if you need to.
Thanks,
Bev
"Rob Lamontagne" <rob_lamontagne@hotmail.com> wrote:
> Hi Bev,
> I plan on installing the laptop primarily for other purposes, MP3,
> XMradio, DVD, GPS navigation, cell phone touchscreen interface, backup
> camera, etc., And the OBD is only one aspect.
> That being said, my intention is to be able to have the OBD interface
> cable connected all the time, and only call up the program when I want it.
> I don't really plan on using the OBD interface on an every-trip basis, but
> in the future I may like to access the appropriate information for real time
> miles/gallon display. What are your thoughts on whether this is a feasible
> plan.
> I've read good things about your adapter and software from MP3Car.com user
> forums. Please let me know what you think. Is there possibly another
> adapter out there you'd like to recommend that would maybe have better
> connectivity results?
> Thanks for being so forthcoming and for your time.
> Rob
It won't help you measure the miles per gallon.
And again, leaving it plugged in may work, but it also may need to be reset
and the only way to do that is to unplug it and start over. It is possible for
transients or other electrical disturbances to cause it to loose connection on
some vehicles, especially while cranking the engine.
I can't really reccomend anything for you because I've not used anything else.
Sorry I can't be much help.
'03 Escape 4WD:
-iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
-Transflective 8.4"
-XM, iG4, OBD-II (BR-3)
-Rearview camera with auto-switching (modified cheesbox)
-Slim Slot DVD+RW
-RR, DFX 4
Zoltan is offline   Reply With Quote
Old 08-08-2004, 02:52 AM   #2
Chairboy's Avatar
I have a BR-3, leave it plugged in all the time, no problem. Only time I had to unplug it was after a dead battery, it acted funky.
Chairboy is offline   Reply With Quote
Old 08-08-2004, 04:28 AM   #3
Zoltan's Avatar
Cool! Thanks Chairboy. I guess I'll tell her to go ahead and send it.
Everyone else have the same experience?
'03 Escape 4WD:
-Transflective 8.4"
-Slim Slot DVD+RW
-RR, DFX 4
Old 08-08-2004, 08:34 AM   #4
Big Zack's Avatar
Same here... I have had my BR-3 connect for over a month now. No problems at all.
I just wish there was a way to set defaults on the application. You have to select the interface, turn on each sensor, select analog gauges, and then maximize each time.
-BZ
Big Zack is offline   Reply With Quote
Old 08-08-2004, 12:06 PM   #5
i have one as well
ive never left it in for a long time ( the obd port is in a crapy place for vw's) but i have had it lose connection before while testing my brothers jetta i just closed the program and opened it back up and that did it for me
crash893 is offline   Reply With Quote
Old 08-08-2004, 05:35 PM   #6
crash893 - u could to to a bone yard and snip a connector out and wire it to your harness above the factory plug so the obd2 isn't in your way. You could also hard wire it to your factory wire harness above the connector if the bone yard is inconvenient.
DavidL is offline   Reply With Quote
Old 08-22-2004, 11:33 PM   #7
Haven't pulled it since the install. Everything running fine.
droswell is offline   Reply With Quote
Old 08-23-2004, 03:47 PM   #8
yea i was thinking about it
it only uses like 3-4 wires ( of the total of 16 pins) so i could just splice them in
Oh where have all the Shutdown Controllers gone (and boot time)? SuperAJ General Hardware Discussion 17 05-21-2005 10:57 PM
OK, one last time... orangewhip General MP3Car Discussion 6 01-30-2002 03:52 AM
Radio and amp connected to speakers at the same time... MattW General Hardware Discussion 11 07-18-2001 10:41 AM
Program that says the time when you press a button brandondere General Hardware Discussion 3 02-12-2001 08:28 AM
leave LCD backlight on all the time??? DJ General Hardware Discussion 5 07-18-2000 05:29 PM
