The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 08-24-2004, 07:51 AM   #1
My Photos: (0)
does this connector means i have obd II ? (Buick 95')
he looks likes obd II ... from the pictures i saw... (sorry for the bad qulity of the pictures.. i took them with my phone..)
so what do you say is that OBD II ?
or it somekind of older version...
cuz from what i understood.. the obd II only start in GM vichels from the year 96 ... and my car is 95...
but mybe my car is model 96 and was build in 95.... i dont know ... what do u say??
and is that vpw? (and not iso?)
thank u all!!!
tomer is offline   Reply With Quote
Sponsored Links
Old 08-24-2004, 08:16 AM   #2
more mods's Avatar
My Photos: (0)
thank u all!!!
You can get the year model from the vin# 10 digit.
10th character- Identifies the model year. For example: 1988(J), 1989(K), 1990(L), 1991(M), 1992(N), 1993(P), 1994(R), 1995(S), 1996(T),
1997(V), 1998(W), 1999(X), 2000(Y)------2001(1), 2002(2), 2003(3)
more mods is offline   Reply With Quote
Old 08-24-2004, 08:40 AM   #3
FLA
gospeed.racer's Avatar
My Photos: (0)
Unfortunately, although it seems to be a obd2 port, it may or may not work. I can only go by Ford as that is what I was trained on, there were many late 94-95 models built with dummy sockets that were only there to ready the cars for the upcoming obd2. It is hard to say for sure, but a trip to the dealer would shurely answer that for you.
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
gospeed.racer is offline   Reply With Quote
Old 08-24-2004, 09:20 AM   #4
My Photos: (0)
thats the problam that they dont really market my car (only the new 2002 + models..) in my country
it have been coustem imported by the man i bought the car from...
il ask the garge or something...
btw... i wannt use obd II
cuz the "ABS" warning light is working ... and i wanna know what the problam...
Old 08-24-2004, 12:03 PM   #5
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
If you in the state, stop by autozone/checkers/kragen and borrow/loan an OBD2 reader to test. If it is a working OBD2 port, the reader will read the code from the ECU. Otherwise, nothing will be read.
What is the manufacture month? Usually if it is August or later, it is the next year model. 9/95 is acually a 96 model.
I think it is ODB2 capable, otherwise GM wouldn't spend money to put the dummy port in there. They may have the cable ready, but not the plug. GM would save tons of money by not putting it there.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 08-24-2004, 07:27 PM   #6
jyaron's Avatar
My Photos: (0)
Post
thank u all!!!
It's GM UART on Pin 9... not OBD2 VPW
jyaron is offline   Reply With Quote
Old 01-21-2007, 12:16 PM   #7
Vehicle: 1988 Mercury Grand Marquis
My Photos: (0)
obd2 port
some gm 94, 95 had the 16 pin 0bd2 port with obd1 system behind it, try reading with a obd1 reader, this can also be done with an analog volt meter, if you need to the the pins for this, let me know, i have a book for every vehicle with obd1.
mastercom2003 is offline   Reply With Quote
Old 01-21-2007, 08:59 PM   #8
My Photos: (0)
1996 was just the year that OBDII was standardized as an industry as all cars had to have it. Their were GM cars prior to 1996 that had OBDII. Yours is probably just what I like to call OBD1.5 OBDII connector with an OBD1 computer in it.
NCHEVYHEVN is offline   Reply With Quote
Old 09-03-2007, 07:03 AM   #9
My Photos: (0)
Hi
If your ABS light has come on it may well be dirt in the reluctor plates on the wheels. Behind each wheel is a proximity sensor and a round disc with notches cut into it around the circumference. These notches can get clogged with dirt and the sensor can not pick up. Take the wheels off one by one and use a wire or stiff brush to remove the dirt.
marksirius is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
98 Nissan Altima OBD II? to carputer??? tsparks Engine Management, OBD-II, Engine Diagnostics, etc. 4 04-30-2006 09:09 AM
FS: OBD II ISO - Digimoto/Scantool ELEmental59437 Classified Archive 11 07-22-2004 11:22 AM
OBD II connector uk? Jamez_Warner Engine Management, OBD-II, Engine Diagnostics, etc. 3 04-25-2004 04:16 AM
Calculate HP base on OBD II data? god_of_cpu Engine Management, OBD-II, Engine Diagnostics, etc. 7 04-16-2004 01:43 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
