Quote: Originally Posted by RogerWilco
I was considering buying the elmscan interface in the box for J1850 PWM, i wanted to check and see if anyone have used, and have decent experiences with it. Thanks
http://www.digimoto.com/order.htm
Digimoto Extra Interface (With Enclosure) & Cables (OBD, Serial)
oh, and it costs 89$ before shipping
from digimoto; about OBD II Cable
it costs 16$.
and what about this ODB-II to serial cable, if i had software could'nt i just use this?
and for refrence, i've searched on this
Yes, I think all you'd need additionally is the software.
I use this stuff:
http://www.ghgcorp.com/dharrison/obdscan.html
at work with my pda, it also comes with windows software. Works pretty good.
Personally I've found that all of this software is pretty much the same. You will only see OBDII related stuff: rpm, mph, o2sensors, tps, coolant temp, and some more, but not much.
You will not see "vehicle specific" trouble code descriptions. You will see the code # (i.e. P1135) but not a description.
All ODBII code start with a "P" and a "0". As in P0446 (EVAP emmissions failure)
It's alot of money to spend for something that is not to exciting. Unless you'd use it at work anyway (like I do)
If I didn't use it at work, or even if I hadn't allready owned the PDA, I wouldn't have spent the money.
Hope this helps?
