09-08-2004, 07:01 AM
#1
Is this an OBD port or not??
This port is in the australian 2002 Turbo Ford Falcon. (XR6T) Someone else here has plugged in a OBD 2 compliant interface and it has'nt worked. I have biult a ELM320 based interface and .....it dont work
what is it?
I know that the furtherest pin top right (with metal in it of course) is GND
and the one furtherest pin bottom left is +12. But no idea what the others is.
anyone got any clues?
09-08-2004, 07:26 AM
#2
Like most things ...  first, you have to realise that this forum is on the majority american based, and like most other things, something that works for their car systems may (but may not) for australian cars.
OBDII is only available in models built after 1996 and then number is very small. There is a better chance of being OBDII compatible in models built after 2000.
Caputer Mk. II
'02 VX Holden Commodore Series II Executive
MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
Morex 60W DC-DC, Custom S/SDC
OS/Software: Developing...
09-08-2004, 04:29 PM
#3
Ok, Ok, Ok... Maybe its just upside down because its an Australian car! Get it? Because of the whole hemisphere thing? Get it? Alright, I know it wasn't that funny. And to Australia, us dumb Americans are upside down... Get it?
Its OBDII, but you're going to have to see what format. And of course, they may have swapped the connectors in your model.
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
09-08-2004, 09:59 PM
#4
Quote: Originally Posted by stimps
This port is in the australian Ford Falcon. Someone else here has plugged in a OBD 2 compliant interface and it has'nt worked. I have biult a ELM320 based interface and .....it dont work
what is it?
My guess at some pins... 13 == Flash Voltage, 2&10 == classic USA Ford PWM, 7 == FISO (Ford ISO)
09-08-2004, 10:01 PM
#5
what is it?
oops... can't forget pins 6&14 == HiSpeed CAN
What year is it?
09-09-2004, 03:03 AM
#6
yeah high speed CAN....is what im fearing....
This is on a 2002 model XR6Turbo (still brand new model actually)
I have tried and tried to source information from techs at ford via email, but of course, they keep their cards held close to their chest......BASTARDS. :P
Ive just biult and got up and running a ELM320 based interface, as someone else,
http://www.emergent.com.au/~cmoran/my_xr6.html
thinks it works, but I have emailed him and like so many people using email these days, no reply
This stinks....Ive spent so much time on this and still no results.
oh and Odessy, i HAVE googled, what on EARTH makes you think i didnt?
I have googled and googled this subject so damn much its getting obsessive!
Jyaron... thank you SO much for your input......much more appreciated than Mr "Oddessy" here, ...ill try that connection tonite
Ive noticed that from this info
http://www.scantool.net/products/obdii_cable_type_b.htm
That the GND pin lines up correct, and the J1850 Bus + pin agrees with the standard, but not the Bus -.
Also, the Standard says Pin 16 is the power. On my car its Pin 9.
Hrmm.......
cheers
09-09-2004, 03:29 AM
#7
Jyaron: no good dude, those pins dont even exist in the plug. There's no metal in there. Actually thats sorta good news, coz it disagree's with CAN which im hoping its not. Want another guess?
09-13-2004, 08:21 PM
#8
 stupid bloody FORD....
somebody help me PWEAAASSE?
Ford XR6T blueprint 4.0 L twin cam turbo.
Xenarc 7" touchscreen M10000 Audigy 2 NX
ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
Griffin Powermate Panasonic DVD-CDW
Pioneer 5x7 Four way, 2x12 pioneer subz
600watt 6chan USA audio AMP
09-14-2004, 10:46 AM
#9
referencing picture: upper right is Pin 1, lower right is Pin 8, upper left is Pin 9, lower left is Pin 16
09-14-2004, 10:11 PM
#10
your serious?
ok that changes things:P
thanks.
09-15-2004, 05:49 AM
#11
Can!?
Ok, this thing is looking more and more like its CAN all the time. I have probed the pins and the voltages seem to agree to the idea that its CAN.
Now, does anyone know of a home biuldable interface that will work with CAN?
with digimoto? or anything else?
cheers. You guys have been the best help
09-20-2004, 03:15 AM
#12
well, good news, for any xr6t owners on mp3car, there is a distributor in OZ about to release a unit, CANscan, which can talk to the CAN in the OBDII in BA falcons,
Im told it is also ISO, so im biuling a scanner for this too.
http://www.norcom.net.au/~bpt/can_scan_tool.htm
Just thought I should mention what Ive found here.
| Thread Tools |
| Display Modes |
Linear Mode
