Quote: Originally Posted by Grayscale
Did you try changing the compatibility settings for the program? Right click the .exe and go to compatibility.
Would that work for DOS based software?
I did try the compatibility settings when after adding a video card I had no display. It turned out that the onboard video was causing that problem. A simple change in the BIOS fixed that, I can see and use the software, just can't communicate with the ECU.
However I will try the compatibility again and post results.
Thanks.
