Go Back   MP3Car.com > Mp3Car Technical Hardware > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 12-27-2004, 08:39 PM   #1
Skipjacks's Avatar
Skipjacks is on a distinguished road
Temp displayed constantly?
I'm going to be installing OBDII reader software soon. Before I did the whole computer thing I had a little computer that displayed the outside air temp.
Now I know the OBDII reads the air temp and sends that info to all the code reader programs for display on screen. But is there a way to extract JUST that temp data so that it displays on my screen all the time? Perhaps on the taskbar or someplace I can see it no matter what other programs are or aren't running?
Skipjacks is offline   Reply With Quote
Old 12-27-2004, 09:40 PM   #2
NiN^_^NiN's Avatar
NiN^_^NiN is on a distinguished road
You could hook up a temp sensor or the orignal sensor and hook it to the PC through serial or usb and just make a small program to stay in the taskbar
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Old 12-27-2004, 11:19 PM   #3
Skipjacks's Avatar
No actually I couldn't do any of that stuff. Hence me asking if anyone else could make a program for me. haha
Old 12-28-2004, 11:21 PM   #4
Iamthehor is on a distinguished road
Your outside temp display is probably not connected in any way to the engine computer(Some newer CAN vehicles may make this statement false, im not up to date on that yet). Intake air temp(IAT) is different than ambient most of the time due to it being in the engine compartment and moving.
Iamthehor is offline   Reply With Quote
Old 12-30-2004, 02:00 PM   #5
Skipjacks's Avatar
Oh, well that's a kick in the teeth to my idea.
There's still got to be a way to extract that ambiant air temp data from the sensor to the computer. There HAS to be.
Old 12-30-2004, 02:10 PM   #6
Paradigm_Guy is on a distinguished road
Although the car has a temp sensor, I don't think it's an OBD2 sensor, so I don't think that an OBD2 port reader would be able to display this. Anyone know for certain that an OBD2 port scanner can display ambient temp?
Paradigm_Guy is offline   Reply With Quote
Old 12-30-2004, 02:19 PM   #7
Skipjacks's Avatar
It depends on where exactly that sensor is too. Our both our cars the intake is right behind the drivers side headlight next to the grill. If thta sensor is in the airbox then the read it gets should be close to ambiant. If the sensor is closer to the manifold, it'll be much much hotter.
Old 12-30-2004, 02:19 PM   #8
You'd be better of taking the temp sensors signal and processing it via the serial port or replacing it with one of your own. theres a thread in HW development that has a link to a schematic and software.......
Time to learn some VB
Old 12-30-2004, 02:23 PM   #9
Skipjacks's Avatar
I don't even know what VB is, let alone being ready to do it! haha
Old 12-30-2004, 02:25 PM   #10
Our sensor is in the driver's side brake duct, it's a yellow and grey probe.
Old 12-30-2004, 02:26 PM   #11
VB=Visual Basic=Programming Language
Old 12-30-2004, 02:27 PM   #12
It's usually about halfway between the air filter and the throttle body, after the MAF sensor. The biggest problems using that sensor is that it will fluctuate with RPM, uses moving (possibility pre-heated) air, and you have no way of telling how accurate it is vs the *C or *f scale. The car doesnt care if the air is 20* or 50* it just reactes the the voltage and compares it downstream with the O2 data to determine the a/f ratio
Old 12-30-2004, 02:29 PM   #13
Our temp sensors have no connection to anything that affects our a/f ratio.
Old 12-30-2004, 02:34 PM   #14
I'm talking about the IAT sensor that he would be reading through his OBD2 interface
The sensor that you are referring to would be much better as it is calibrated for reading ambiant temp and already has the support electronics built in. If the display was a only for outside temp and the electronics are with the display, I'd bet that the data being sent is a standard protocol and might just act nicely with a serial port but i have no way to test that theory and my experience with german engineering is that they like to reinvent the wheel in many cases.
Skipjacks, if you are interested in learning a little programming, VB is pretty easy to pick up the little stuff on.
Old 12-30-2004, 02:37 PM   #15
Skipjacks's Avatar
I see you're familiar with BMW's then...hahaha
Honestly I just bought clips to hold trim peices on the car today and they are the 4th different design I've seen for little plastic clips for the same car! Wouldn't suprise me if the whole car is programed with BMW's own custom OS.
anyone know the ide running temp for athalon 64? rusty General Hardware Discussion 7 10-05-2004 09:07 AM
max temp Intel Celeron 1.3 GHz Sway General Hardware Discussion 4 02-02-2004 11:25 AM
Does the Nehemiah board come with a heat temp sensor bertybassett General Hardware Discussion 3 10-02-2003 03:03 PM
running laptop constantly 98explorerxlt General Hardware Discussion 6 08-23-2003 06:10 PM
Need help finding idle and temp sensors wizardPC Off Topic 0 05-06-2002 11:40 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
