The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 01-27-2005, 07:00 AM   #1
ShawJohn's CarPC Specs
ShawJohn's Avatar
Vehicle: 1999 Nissan 200sx S14a (280bhp)
My Photos: (0)
Question PLS Recommend a Scantool for Nissan 200SX (S14a)
Can anyone recommend a OBD scantool and software to connect my 2000 Nissan 200SX (S14a), Engine Code: SR20DET to my CarPC. I use FP and CF on the CarPC.
I have 'd & 'd but there is so many results coming back and I know nothing of OBD & OBDII. I heard that UK Nissans have a slightly different OBD protocol than US Nissans, would this affect the equipment needed?
Any help or advice is appreciated.
John
ShawJohn is offline   Reply With Quote
Sponsored Links
Old 01-27-2005, 12:51 PM   #2
9 Fingered Administrator
Lesbian
frodobaggins's Avatar
Vehicle: 1998 Ranger/1991 Sunbird
My Photos: (0)
Should be ISO. So get one that can do ISO.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 01-28-2005, 10:06 PM   #3
Auri's Avatar
Vehicle: 2005 Dodge SRT-4
My Photos: (0)
Go to Scantool.net (www.scantool.net) and check out their solution. They also have free downloadable software for diagnosing via OBD-II. They have a good list of OBD-II interface types as well (which I've helped update).
My book, "Geek My Ride", comes out in April and will have a good list of OBD-II interface types as well as an extensive resource directory.
Check it out: http://www.wiley.com/WileyCDA/WileyT...764578766.html
Best,
-Auri Rahimzadeh
Author
"Geek My Ride"
Auri is offline   Reply With Quote
Old 09-08-2005, 07:39 AM   #4
ShawJohn's Avatar
My Photos: (0)
This is what I found out...
Its most definately not ISO.
Is Nissan's own proprietry system called Consult... It has an odd ball DDL connector that you can't buy plugs for, and doesn't use the OBDII standards but its own.
There is software available for this interface but its about £260 which is a bit steep really IMO. There are free versions but these have limited functionallity.
Old 09-22-2005, 03:04 PM   #5
ShawJohn's Avatar
My Photos: (0)
Just got my Consult Interface.
The 1999 Car & the 2000 Car I wrote off don't have OBDII but Nissan Consult.
The adapter came from http://www.plmsdevelopments.com/consult_if.htm
Not had chance to try it yet...
Old 10-20-2005, 03:49 PM   #6
Vehicle: 1996 Nissan 240sx
My Photos: (0)
hey cool another S14 owner... how did that interface work out for ya? I'm thinking about buying one myself (altho I'm not the fortunate owner of a SR20DET - I do plan to go turbo with a KA24DE-T eventually)
I'm also curious as to your screen install... here is mine:
no custom bezel, just cut the insides of the stock bezel a bit and used the oem under radio cubby to make a custom mounting bracket for the screen. - I still gotta get rid of the white writing on the screen
edit - nvm on the screen, I just found this - http://www.mp3car.com/vbulletin/showthread.php?t=61280
DaPCWiz is offline   Reply With Quote
Old 10-20-2005, 04:10 PM   #7
ShawJohn's Avatar
My Photos: (0)
Hello fellow SX'er, Is yours an S14 or an S14a? The 'A' has a different more aggressive front end
Your screen does look quite tidy, but I was put off mounting it there cause I need to retain the HU for radio and amplification, and there was a lot of glare. Mounted high it mainly reflects off the roof!
most of the info on my screen install is here
Why not keep the SR20DET and tune it instead of using the KA...?
a FMIC, 555cc Injectors, Mechanical Boost Controller, ECU Chip, Induction and 3" turbo back exhaust will see 300bhp+. Plus the SR is smaller and weighs less
Norris designs do a crate SR engine pushing over 600bhp.
lots of tuning info (and loads of other stuff) available on http://www.sxoc.co.uk/vbb/index.php?
HTH
John
Old 10-20-2005, 04:15 PM   #8
My Photos: (0)
The USDM S14 comes with a KA24DE, not an SR20 If I had an SR20 stock I'd never let go of it... I have a Infiniti G20 (Nissan Primera) as well.. and the SR20 in that is awesome. My KA is low milage and in good shape so I think I'm gonna take that route.
I have a zenki S14, I like the rounded front end
http://www.cardomain.com/id/dapcwiz <-- my s14
Old 10-20-2005, 04:22 PM   #9
Vehicle: '94 Nissan Primera eGT
My Photos: (0)
Which software are you using with the Consult interface ?? Tom's Datascan ??
http://www.mp3car.com/vbulletin/showthread.php?t=54420
He will be releasing a new version soon apparently. There are a few other programs out there that work aswell. Calumsult is cool looking, also check out TECU. I haven't used the last two due to my laptop being stolen and my M10k Mobo being funked
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 10-20-2005, 05:20 PM   #10
ShawJohn's Avatar
My Photos: (0)
Got all of em apart from TECU Will go find that now and have a play.
Never used any of them in car as haven't fitted PC yet, and laptop has no serial connectors
Sponsored Links
Old 12-21-2007, 11:52 AM   #11
My Photos: (0)
Hey Silvia owners
Like to see someone familiar around
I own 98 200SX S14A
Where do we find OBD connector did somebody solved this ?
And can some of you please post links of CarPc pictures in your Nissans please
pccopat is offline   Reply With Quote
Old 12-28-2007, 05:50 PM   #12
My Photos: (0)
Consult II..... nothing else it's a biderectionnal and it can be drive via a carpc....and you can reflash your PCM for better performance .... 4 ser20det around here are reprogram ease and userfriendly .... I think you can get 3-4 % more HP ...
Qc_elite13r is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
