The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 08-28-2005, 05:16 PM   #16
See me in my wet t-shirt.
stevieg's Avatar
Vehicle: Ford Focus MP3
My Photos: (0)
Quote: Originally Posted by Erorus
PHP Code:
Function GetMPG(tMAF As VarianttSpeed As VarianttLTFuelTrim As Variant) As Variant
''MAF is maf_air_flow sensorTo convert from what the OBD returnsvalue=OBDData 0.01
''tSpeed is vehicle speed in MPHTo convert from what the OBD returnsvalue=OBDData 0.621371192
''tLTFuelTrim is long-term fuel trimTo convert from what the OBD returnsvalue=0.7812 * (OBDData 128)
    If
IsNull(tMAF) Or IsNull(tSpeed) Or IsNull(tLTFuelTrimThen
        GetMPG
Null
Exit Function
End If
Dim tMPG As String
'' Do MAF over an hour
    tMAF
tMAF 60
    tMAF
tMAF 60
'' Turn into KG/litre equivalent
    tMAF
tMAF 1000
'' Get petrol flow based on 14.7:1
    tMAF
tMAF 14.7
'' convert litres to gallons
    tMAF
tMAF 0.219969157
'' convert long term fuel trim to percentage
        tLTFuelTrim
= (tLTFuelTrim 100) + 1
'' Calculate MPG
    tMPG
= (tSpeed tMAF) * tLTFuelTrim
    GetMPG
FormatNumber(tMPG1TrueFalseFalse)
End Function
The problem I have with this is the air flow sensor is very optimistic, and you probably run richer than this formula indicates. It says I average around 60-90MPG when cruising on the hwy and up to 200+ MPG when coasting. However, it does change when you have the pedal down, etc. I forget where I stole this code from.
It looks like my botched attempt at MPG conversion I think.
I didn't think it was accurate as it could be either, and haven't actually used it in real-life.
Any idea what could be done using the OBD to get a more accurate measure?
Ford Focus MP3 : www.stevieg.org/carpc
Car PC Status: COMPLETE
stevieg is offline   Reply With Quote
Sponsored Links
Old 07-15-2007, 10:57 PM   #17
My Photos: (0)
does anyone have this class working?
If so, could you post a sample app to be looked at?
Thanx
planethax is offline   Reply With Quote
Old 07-16-2007, 07:09 AM   #18
Vehicle: 2005 Mazda 6s
My Photos: (0)
Quote: Originally Posted by takissd View Post
great! will that work with vb.net??? if yes, how?
You can attempt to convert it into .NET. But its very possible it will get botched up. At least that's been my experience with most of the .NET conversions I've done.
2005 Mazda 6s
2002 GMC Envoy SLT
Digital Deviation
Addict is offline   Reply With Quote
Old 07-17-2007, 07:43 AM   #19
My Photos: (0)
Hi guys, I am programmer too. While I am mostly involved in database/plsql programming I have fooled around with C/C++ and some VB. Assembly too!
Can anyone tell me if there would any substantial performance difference between a typical serial communication tool for OBDII written in C/C++ versus VB/.net ? Think CAN too.
It's A Honda is offline   Reply With Quote
Old 07-17-2007, 04:43 PM   #20
My Photos: (0)
Sample app that I am trying to get to work with this class, I am not sure how to "pass a mscomm control, the port number, and a timer control to it" ?
Can some one help get me started with this?
Sponsored Links
Old 07-20-2007, 03:10 PM   #21
Erorus's Avatar
Vehicle: 2002 Mitsubishi Eclipse
My Photos: (0)
I wrote this class back in the day.. Basically, once you create mscomm1 and timer1 you'll never need to touch those controls. When you use
dim withevents elm as clselm323
then you should see "elm" as a control in the code window with its own events. Those events fire whenever things happen with that class. So you don't have to handle mscomm1_oncomm at all.
Let's say that your elm323 is on com2.
strReturn$ = elm.openELM(mscomm1, 2, timer1)
if strReturn$ = "" then
msgbox "opened successfully"
else
msgbox "open error: " & strReturn$
end if
private sub elm_statusmessage(byval strMessage as string)
debug.print strMessage
end sub
private sub elm_OBDReturn(ByVal bMode As Byte, ByVal bPID As Byte, ByVal strData As String, ByVal lngData As Long)
msgbox "OBD Returned mode " & cstr(cint(bMode)) & ", pid " & cstr(cint(bPID)) & ": " & cstr(lngdata)
end sub
Erorus is offline   Reply With Quote
Old 10-06-2007, 04:09 AM   #22
My Photos: (0)
You might want to convert tSpeed from kph to mph
Quote: Originally Posted by Erorus View Post
PHP Code:
tSpeed As VarianttLTFuelTrim As Variant) As Variant ...
skewbe is offline   Reply With Quote
Old 10-09-2007, 02:04 AM   #23
My Photos: (0)
First of all thanks Erorus for nice class. I was able to implement OBD read VB program in few hours.
http://www.mp3car.com/vbulletin/engi...-maf-obd2.html
I tried using the MPG calculation in above thread and it seems to be pretty accurate. Many constants are similar to what is shown in this thread but this thread seems to be missing pound to gallon conversion and seems to be off by 10x as well. I see that the fuel trim is used here. I'll try to apply that. Looks like it may give you better estimate for your car rather than looking for ideal values.
The equation I am using is
14.7 g of air / 1 g of gas * 6.17 lb / 1 gal * 454 g / 1 lb * VSS Km / 1 h * 1 Mi / 1.609344 Km * 1s / MAF (100g from OBD) * 100g * 1 h / 3600 s * (0.7812 * (LTFT - 128) + 1)
Which will be
710.7 * VSS / MAF * (0.7812 * (LTFT - 128) + 1)
When cruising I get about 20 MPG and when I press the clutch I get like 105MPG which kinda makes sense.... =P When I calculate MPG when I fuel my car I get about 23MPG so I think this is pretty close.
Erorus, do you know if there is a way to read the OBD data in burst fashion? Or is this the limitation of ELM chip? I tried to tune the time to read the data from OBD but reading those three data takes at least 2.5 s. I kind of want to be able to read all three at the same time to increase the accuracy. In 2.5 second many things can change.
Is there a way to read back the data more quickly?
If not I guess running average or something similar can be implemented I suppose.. =)
Regards
hjcho616 is offline   Reply With Quote
Old 10-09-2007, 02:38 AM   #24
My Photos: (0)
Actually instead of 0.7812 it should be -0.007812. I forgot this was in percentage and also positive value means on LTFT means using more fuel.
Regards
Old 10-09-2007, 09:33 AM   #25
My Photos: (0)
I found my error regarding data ready time. I've set the timer interval before openELM function so default must have been assigned. I was able to set it to 200ms without getting any errors. However it would still be nice if we can read the data at the same time though. Is this possible?
Regards,
Old 10-28-2007, 12:39 PM   #26
My Photos: (0)
Wouldn't it be easier to just use injector duty-cycle, engine RPM, and speed to derive this data?
oroboros_ARR is offline   Reply With Quote
Old 10-28-2007, 12:40 PM   #27
My Photos: (0)
I know nothing about PHP and I also know very little about what is avalible from the OBD2 interface, but here goes:
Old 10-28-2007, 01:00 PM   #28
My Photos: (0)
PHP Code:
Function GetMPG(tIDC As VarianttSpeed As Variant) As Variant
''tIDC is injector duty cycle
''tVFF is volume fuel flow.
    If
IsNull(tIDC) Or IsNull(tSpeedThen
        GetMPG
Null
Exit Function
End If
Dim tMPG As String
    Dim tVFF
As String
'' Do VFF (gallons/minute)
tVFF tIDC 250 0.000264172051
'' Do Speed in miles/min
    tSpeed
tSpeed/60
'' Calculate MPG
    tMPG
= (tSpeed tVFF) * tLTFuelTrim
    GetMPG
End Function
This is with 250cc/min injectors. Would something like this work?
Old 05-05-2008, 09:32 AM   #29
My Photos: (0)
Yes i always wanted to make one of these. But i dont know how im not that smart of a person. But i love to learn ... You people know any good places to find codes for this stuff.
Dtecneon is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Able to get voltage from OBDII? aoLhaTer Engine Management, OBD-II, Engine Diagnostics, etc. 10 07-18-2007 09:26 PM
FS: OBDII diagnostic interface deskcom Classified Archive 0 12-09-2004 11:24 PM
@ Leddy OBDII gyro NeoCar Media Center 4 12-08-2004 06:43 PM
Pick my Programing class for me! Sonicxtacy02 Off Topic 14 11-23-2004 08:59 PM
1994 Saab 900 & OBDII Shark General Hardware Discussion 2 11-03-2003 08:58 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
