Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 02-16-2005, 08:31 PM   #1
Erorus's Avatar
Erorus is on a distinguished road
Yet Another OBDII VB6 Class
Here's my version, folks.. it's a class so you make it an object and use its functions/subs/events to communicate with it in your application. Practically plug-and-play.
Works with the ELM323 chip found in scantool.net's OBD devices. The 323 is the ISO version, but I bet this exact code will also work with the other ELM chips (ELM320 and ELM322).
http://www.apeirokalia.com/elm323/
Erorus is offline   Reply With Quote
Old 02-17-2005, 08:28 AM   #2
See me in my wet t-shirt.
stevieg's Avatar
stevieg is on a distinguished road
Thanks... Looks good.
So basically, once the inital setup is done, you fire a command to it and an event comes back with the data?
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
stevieg is offline   Reply With Quote
Old 02-17-2005, 08:29 AM   #3
stevieg's Avatar
by the way... Yet another VB6 elm class? Where are all the others???? I thought this was the first?
EDIT:
I would like to use this to finish off my MPG meter.. Do you have a sample app to give me a better idea of how to use the class?
Old 02-17-2005, 09:36 AM   #4
Erorus's Avatar
That's the idea exactly.
EDIT:
Well, I see a lot of VB code on this so I tacked "Yet Another" on the subject line. The thing I like about the class is it isn't fully embedded in a form that you have to take apart to figure out how to use.
I don't have a sample app for ya, sorry. Maybe if I get bored in the next few days.
Old 02-17-2005, 10:48 AM   #5
takissd's Avatar
takissd is on a distinguished road
great! will that work with vb.net??? if yes, how?
-VIA EPIA M10000/512MB/40GB HD
-DWW motorized 7'
-BU 303 GPS w/iGuidance/ CF
-Opus90w
-Belkin Bluetooth
-Pioneer HU
[||||||||||] 95% done
takissd is offline   Reply With Quote
Old 02-17-2005, 10:52 AM   #6
Erorus's Avatar
No idea, I don't have VB.net. Worth a shot, tho.
Old 03-12-2005, 12:22 PM   #7
kocke is on a distinguished road
I can't download the class
can you send it me?
thanks and regards
kocke is offline   Reply With Quote
Old 03-12-2005, 12:56 PM   #8
Erorus's Avatar
Please try it again from the webpage, I changed the URL. When you download it, just cut off the .txt extension.
Old 03-12-2005, 02:08 PM   #9
thanks, now it works
Kind Regards
Old 03-22-2005, 09:23 PM   #10
blaster is on a distinguished road
can I use VAG TWIN COM with it?
ProjectEZP.com – next generation police speedtrap locator. Free database for your GPS system (includes US/Canada).
blaster is offline   Reply With Quote
Old 03-22-2005, 10:45 PM   #11
Erorus's Avatar
Probably not.
Old 04-07-2005, 09:22 PM   #12
carabuser's Avatar
carabuser is on a distinguished road
So anyone used it yet?
2000 Maxima CarPC
Current Status: Rebuilding
Specs
- 1.5Ghz Toshiba Laptop
- Indash Motorized 7" VGA TS
- DeLorme GPS
- Power Inverter
- Pioneer HU
carabuser is offline   Reply With Quote
Old 04-08-2005, 05:40 AM   #13
stevieg's Avatar
Yes!!!
I'm using it! It works - My app isn't finished yet, but it's a re-hash of this:
http://www.mp3car.com/vbulletin/engine-management-obd-ii-engine-diagnostics-etc/32692-obdii-elm-mpg-meter-almost-working-but-not-quite.html
The OBDII stuff is working very well. I've successfully had it running for hours on end pulling out the data. My MPG calculations seem to be a bit iffy though - I am having trouble finding a comprehensive list of all the basic formulas for temp, mass air flow etc for when I'm converting from the output long to it's 'real' value! I found one a long time ago when I first started on this, before your VB6 class, but can't find it now, so having a little trouble double checking everything.
I haven't tested standby/resume properly yet - my only try resulted in failure but I was thinking about polling for the standby system call and disconnecting, then on resume reconnecting if it causes any issues - my main thing is getting the instant MPG quick and reliable.
But yes... It works!
Old 08-28-2005, 11:28 AM   #14
knubile's Avatar
knubile is on a distinguished road
Any progress on this? I'm wondering if MPG calculations are possible using OBD-II.
knubile is offline   Reply With Quote
Old 08-28-2005, 06:07 PM   #15
Erorus's Avatar
PHP Code:
Function GetMPG(tMAF As VarianttSpeed As VarianttLTFuelTrim As Variant) As Variant
''MAF is maf_air_flow sensorTo convert from what the OBD returnsvalue=OBDData 0.01
''tSpeed is vehicle speed in MPHTo convert from what the OBD returnsvalue=OBDData 0.621371192
''tLTFuelTrim is long-term fuel trimTo convert from what the OBD returnsvalue=0.7812 * (OBDData 128)
    If
IsNull(tMAF) Or IsNull(tSpeed) Or IsNull(tLTFuelTrimThen
        GetMPG
Null
Exit Function
End If
Dim tMPG As String
'' Do MAF over an hour
    tMAF
tMAF 60
    tMAF
tMAF 60
'' Turn into KG/litre equivalent
    tMAF
tMAF 1000
'' Get petrol flow based on 14.7:1
    tMAF
tMAF 14.7
'' convert litres to gallons
    tMAF
tMAF 0.219969157
'' convert long term fuel trim to percentage
        tLTFuelTrim
= (tLTFuelTrim 100) + 1
'' Calculate MPG
    tMPG
= (tSpeed tMAF) * tLTFuelTrim
    GetMPG
FormatNumber(tMPG1TrueFalseFalse)
End Function
The problem I have with this is the air flow sensor is very optimistic, and you probably run richer than this formula indicates. It says I average around 60-90MPG when cruising on the hwy and up to 200+ MPG when coasting. However, it does change when you have the pedal down, etc. I forget where I stole this code from.
Able to get voltage from OBDII? aoLhaTer Engine Management, OBD-II, Engine Diagnostics, etc. 10 07-18-2007 10:26 PM
FS: OBDII diagnostic interface deskcom Classified Archive 0 12-10-2004 12:24 AM
@ Leddy OBDII gyro NeoCar Media Center 4 12-08-2004 07:43 PM
Pick my Programing class for me! Sonicxtacy02 Off Topic 14 11-23-2004 09:59 PM
1994 Saab 900 & OBDII Shark General Hardware Discussion 2 11-03-2003 09:58 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
